×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
AX8 Nighthawk drops signal strength for no reason
redbird97
So my AX8 will just drop the strength to all of my devices for no reason. I noticed it more since i began streaming games from my PC to my iPad.
I checked the the signal strength in the app to my devices and it was one bar on everything (all wifi devices though show strong connection on the devices themselves). I found that doing a speedtest kicks the router in the butt and seems to get things back to a tolerable level for a little bit.
See the screenshot to see the before, and then immediately after running a speedtest.
Firmware: 1.0.5.132_1.0.69
Any ideas?
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 4
Guru
Re: AX8 Nighthawk drops signal strength for no reason
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 4
redbird97
I’ll try the channel suggestions.
Message 3 of 4
Guru
Message 4 of 4
Discussion stats
  • 3 replies
  • 624 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
