× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Add USB drive to RAX200
PADWIS
Follower
How do I add a USB drive to router
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 2
Guru
Re: Add USB drive to RAX200
First make sure you get a drive that'll work with readyshare.
https://kb.netgear.com/18985/Will-my-USB-drive-work-with-ReadySHARE
this isn't all inclusive but its just a list of reported drives that have worked.
then make sure you have it in the correct format.
https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-my-Nighthawk-router
Then read through the manual a little bit. Starts in section 8, page 120
https://www.netgear.com/support/product/RAX200.aspx
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1576 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
