- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ax4200. Rax43
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ax4200. Rax43
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ax4200. Rax43
WPA3 depends on your client devices supporting WPA3. If they don't then they won't connect if the router is set to WPA3. If WPA2/WPA3 is available try that mode. If not, you'll need to set WPA2/AES only.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ax4200. Rax43
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ax4200. Rax43
Will have to ask those Mfrs if there going to implement WPA3. It will be up to them to do that.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ax4200. Rax43
@larrysfishingse wrote:
Yeah that's what I said it back to WPA Aes I find it hard to believe that the smart TV smart cameras Bose radio nothing worked oh well that was one of the specifications selling features using the best security thanks for your help
If you use only wpa3, then the devices have to have wpa3 built in. Not many do. Which is the point of mixed wpa2/wpa3 mode if the router supports it.
the problem with switching to newer wifi protocols is some older devices don't support them. So you either use an older protocol, use a mixed mode, or simple run an old AP for those devices.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
