× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Fowarding multiple ports on RAX50
din_dawn
Tutor
I am not able to foward multiple ports within a service.
For example, if I enter "21, 80, 500, 5000-5001" and apply, only port 21 is forwarded (Pic 1 &2 is what I entered and what actually applied).
My firmware version is V1.0.5.106_2.0.70, is there any solution to fix it? Thanks.
Message 1 of 9
Guru
Re: Fowarding multiple ports on RAX50
does it work if you just add a couple and not the whole range? (for testing)
Or are you able to go back in and modify it?
Message 2 of 9
din_dawn
Tutor
I found out that I can foward a range of ports (eg. 1-100), but not putting different ports with comma. The problem remains if I go back to modify it. Thanks you help though
Message 3 of 9
Guru
kind of a PITA but if you can add them individual it could work.
Luckily you don't have a ton.
Once you've done so, I'd make a backup configuration. That way if you ever factory reset, you can restore the port forwarding easier.
Message 4 of 9
din_dawn
Tutor
That's the ports I needed lol.
Sure I will make a backup for this, hope Netgear engineers will fix it in the future.
Message 5 of 9
Guru
hope you don't need to use the backup but glad the work-around works.
Message 6 of 9
Razor512
Prodigy
Try using just single values separated by a comma rather than a combination of single values and ranges in one entry. If it doesn't work then it could be a UI related bug.
Message 7 of 9
KB2MXV
Initiate
Any update on this issue?  I'm in the same boat with the RAX50.  My older R7450 works as expected
Message 8 of 9
LincolnOtter
Same issue here. Looks to be a UI bug. Form strings not being parsed correctly.
Firmware Version V1.0.11.112_2.0.77
Message 9 of 9
Discussion stats
  • 8 replies
  • 1608 views
  • 3 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
