×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
MR60 Mesh Nighthawk how many devices can I connect?
Jaime10
Tutor
I recently purchased this router. I read that you can connect 25 devices. I currently have 14 devices and plan to add the Ring alarm system which will add another 20 devices. I wonder if having 45 devices connected will degrade the speed of the system. I wonder if anybody have any experience with similar situation. Thanks in advance.
Message 1 of 5
Guru
Re: MR60 Mesh Nighthawk how many devices can I connect?
How many clients can you connect wirelessly to a NETGEAR router? | Answer | NETGEAR Support
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 5
Jaime10
Tutor
Thanks for the quick response. I looked at the link you sent me but I do not see the MR60 model listed in the list showing "This article applies to:
Not sure if it goes by a different model number or if it is a new model and the list has not been updated by Netgear. Should I assume that it also applies to my model?
Thanks again for your help.
Message 3 of 5
Guru
That list hasn't been updated since 2016.
I'd doubt that your device supports less than the older devices but anything is possible 🙂
Message 4 of 5
Jaime10
Tutor
Thank you very much.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1876 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
