× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
NIGHTHAWK AX8 CANNOT SAVE DEVICE NAMES
IamHandyAndy
Hello Again.
I have run into another issue on my NIGHTHAWK AX8 , I cannot save device names.
On the device manager section, you can select the individual devices and edit them but when you click done and then save you get Sorry, the action was failed. Please try again. It never works have tried many times over a couple of days and a few reboots.
I see there are a few old threads with similar issues but not really any solutions .
Anyone know the fix?
TIA,
HandyAndy
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 4
Christian_R
NETGEAR Employee Retired
Re: NIGHTHAWK AX8 CANNOT SAVE DEVICE NAMES
Hello IamHandyAndy,
May you confirm whether you're on the Nighthawk App or the web GUI.
Thanks,
Christian
Message 2 of 4
IamHandyAndy
Hi Christian,
It is only with my iPhone I am having the problem. I was able to get in and make the changes from my desktop computer.
Now that I have it setup correctly, it is just  a matter of curosity why I cannot do it from the phone.
Thank You,
HA
Message 3 of 4
Christian_R
Hello IamHandyAndy,
Thanks for confirming! Our engineering team is aware of the issue with the Nighthawk App and is currently investigating.
Christian
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 752 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
