- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nat type still moderate,no ipv6,upnp not successfull AX RAX120
- Mark as New
- Bookmark
- Subscribe
- Permalink
so i made the ipv6 from secured to open,upnp has been on,i port forwarded all 7 ports,under lan setup i put Address Reservation for the series x ip. and it is still no IPV6,no UPNP,nat moderate.
and also this series x always had ipv6,upnp successfull,nat open. only two days ago these issues started happening. then i went ahead and made the changes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nat type still moderate,no ipv6,upnp not successfull AX RAX120
Hello Zeus408,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
