- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AX4: DHCP Not Working - IP not assigned automatically
- Mark as New
- Bookmark
- Subscribe
- Permalink
So, I have had this router for a few months now and I have had issues with wifi on numerous ocassions. At random, the router will begin to not distribute and assign ipv4 ip address for devices connected to the network. Only upon connecting the device via a static ip address does the device begin to access the internet. This also applies to devices connected via ethernet to the router. (i.e. my iPhone will connect via wifi to the SSID but will have an exclamation point through the wifi icon and says "No Internet Connection". Only after changing my ipv4 address settings for the connection to a static ip will it have internet access)
I believe this is due to the DHCP server not assigning ip addresses to connected devices. I can see that a self-assigned ip address is in my device wifi settings. What are my options for a non-functioning DHCP Server?
Steps I have already taken in attempt to resolve:
Updated to latest firmware (Currently: Firmware Version V1.0.3.64_1.0.1)
Downgraded to previous firmware versions
Rebooted both the router and modem
Disconnected all devices wireless and ethernet
Enabled ipv6
Removed SSID security (open network)
Access Control is disabled
Changed router ip address
Disabled AX
DHCP pool is 192.168.2.10 - 192.168.2.254
I am not an IT professional so debugging this is beyond my knowledge so any help is much appreciated. The only thing that seems to work is reseting the router which is a hassle since I am having to do this every month or so. Thoughts??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk AX4: DHCP Not Working - IP not assigned automatically
Hello 1appleluvr,
Welcome to the community! I'd like for our support to get in contact with you for further assistance. Please send me a message with your contact info and serial number.
Thanks,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Private message Sent. I will update this post accordingly with any resolution as I receive it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have not received a resolution from Netgear support.
The only solution that seems to work for me is to reset the router and start network settings from scratch again. I do this about once a month or so.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you have the same issue as me with your DHCP server, if you set the IP address of your device to a static IP and static DNS it worked for me. That would technically work but devices that I cannot set static IP addressess on would not be able to connect. Along with the fact that new devices temporarily trying to access my wifi would have to forego this tedious process just to connect, it is not acceptable from a brand and luxury product like Netgear is.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Today I received a response from Netgear. They are refusing to provide me support for this issue on the sole basis that I did not purchase from an "authorized Netgear reseller". I purchased it online from a person who longer wanted the router.
Not exactly what I would call good customer service. Regardless of where someone purchases your product, support should be available. Bottom line is that I have not opened, altered or otherwise changed how the product functions so reseller or not, support should be a given.
I am dissapointed in Netgear. I will be forced to purchase my next router from a different manufacturer that cares enough to support all the products they produce rather than only the ones sold by resellers deemed "authorized".
- Mark as New
- Bookmark
- Subscribe
- Permalink
In the meantime, if anyone has any actual solutions they would like to share, please do!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately, that's not how these things work.You will find that other brands have similar rules. Check before you try something else.
In any case, "free" support is for only 90 days.Basically it is set-up support.
Your best bet is to persevere with this place by providing as much information as possible, with details of what you have done and where it goes wrong.
For a start, have you tried different firmware? Sadly, latest is not always greatest.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi guys. Just wantet to hear if anyone has any other ideas except for static IP and DNS for this issue. I'm having similar problems acros multiple devices using the wifi.
They seem to be connecting fine, but getting wrong ot no DHCP data. Usually rebooting the device or the router seems to fix it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Greetings all on this post.
I am having the exact issue with a Router I bought from Best Buy. It started doing this same thing right as the 90 day free service was expiring. I have to manually assign IP Addresses for all devices on my network. Has there been any feedback or a solution to fix this issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can never really know that. The symptoms may seem the same, but that could be down to different underlying issues.
You might do better to start your own fresh discussion, especially as this one does not have a SOLVED flag.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No luck for me, but thanks for the suggestion. I had an old R6220 set in AP mode, so I ended up swapping my R6220 and RAX40's roles, set the RAX40 in AP mode. Hopefully Netgear will fix it in the future and I can use it as my router like I hoped for. Lost an entire day fighting with this stuff.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is the fix:
DO NOT USE THE APP!!
I pulled out my laptop and went to their website. Netgear support. Downloaded the latest firmware. It is about 35mb. I installed this through the Microsoft edge browser. Typed in the router's ip address in my browser and used the tools on here to update it. It said that the router had the same firmware I was updating to. I still did it. This worked!! Fix the problem.
I called support back and he told me that updating over cellphone with cellular data is a bad idea.
Hope this helps you guys out!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is the link to the screen shot in the initial post.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had that very same problem with an R8000 router. Tried for about a year to fix the problem but never figured out what the problem was. If I did a factory reset and manually reset my custom configs it would work for a few weeks than went back to not assigning IP addresses to wireless devices without a static IP. Netgear was no help because the router was older thann 90 days.
I couldn't take it any more. I dumped the R8000 and bought a RAX80. So far it's working (3-weeks) but it has issues too.
If anyone figures out the problem please post it here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear would not talk to me about how to fix it unless I gave them 139 but he did email me a link to how to manually update the firmware.
The main problem is it says everywhere to use their app. I tried the app first. It appeared to go smooth but errors still occurred. So I downloaded the firmware and unzipped it on my laptop. I then installed it with a brand new ethernet cord.
I called back and explained to the tech guy exactly what I did. He admitted that updating with a computer is better than using a phone app. The app downloads and uploads at the same time, while the computer will download it first and then upload it all at once.
I turned off auto updates and will manually update fro. This point forward
