- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AX4 refuses Oneplus 6 after Oxygen OS 10.0 (Android Q) update
- Mark as New
- Bookmark
- Subscribe
- Permalink
The password hasn't changed.
I've tried rebooting the phone and rebooting the router.
I've tried on the 5GHz and the 2.4GHz.
My family who have other phones under Android 9 have no issues.
Also, my phone connects properly to public Wi-Fi services.
So I'm deducing it's an issue between Oxygen OS 10.0 and the Netgear Nighthawk RAX40.
Is anyone else having this issue?
Any ideas as to a solution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk AX4 refuses Oneplus 6 after Oxygen OS 10.0 (Android Q) update
A couple things to try.
1. Go into the oneplus 6 and forget the network and then reconnect.
2. Does your ssid or password have special characters in it? If so, try removing them.
3. Are you using smart connect?
4. The oneplus doesn't have ax. Try disabling it. maybe something is conflicting with their implementation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not using AX on the router, precisely because I have no AX-compatible devices yet.
No special characters in the password.
I've tried going into flight mode, forgetting networks, rebooting both phone and router, wiping the cache partition on the phone, putting Wi-Fi back on.
The connection states "connecting", then goes to "saved" and stays at that status, never "connected".
This is the case for both 2.4 and 5 GHz bands.
My OnePlus 6 connects with no issues to all other Wi-Fi networks, both public and private.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a similar issue with my One Plus 6t. I recently bought the Netgear nighthawk ax4 wifi 6 router, and I am unable to connect my one plus 6t (Android 10) to it.
I could sign in from my wife's Samsung Galaxy s9.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've delved a bit deeper into the issue.
It appaears that the latest Oxygen OS 10 update on my OnePlus 6 device does not support WPA2 encryption over Wi-Fi.
If your router is cofigured with "WPA2-PSK (AES)" encryption, try downgrading it to "WPA-PSK (TKIP) + WPA2-PSK (AES)".
With this setting, devices that support WPA2-PSK (AES) will connect using this encryption and those that don't will connect using "WPA-PSK (TKIP)".
This worked for me while I wait for OnePlus to provide a proper OxygenOS 10 upgarde that supports WPA2-PSK (AES) just as the version 9.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you! Much appreciated, i shall try and let you know.
