- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AX6-RAX45 latest firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Nighthawk Nighthawk AX6-RAX45. The current version in my router is: V1.0.2.82_2.0.50
It seems there are newer versions of the firmware out there but when I go to the Router Update option and select "Check" it tells me "No new firmware version available."
So I have 2 questions:
1. What is the latest firmware version for this router?
2. Why the built in option to update doesn't find newer versions of the firmware?
Thanks.
-Ron
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk AX6-RAX45 latest firmware
1. What is the latest firmware version for this router? Check here for whats most current:
https://www.netgear.com/support/
Input your router model #.
Some times NGs web site gets updated before the auto update servers. So they may not be on the same page.
You can always manual update FW as well:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
User | Count |
7 | |
4 | |
3 | |
2 | |
1 |
