× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Looking to buy the NETGEAR - Nighthawk RAX45 AX4300 WiFi 6 Router
heshie75v
Follower
     Must I have a cable modem to install this router, or is it enough to have a Cat 5 ( I believe its called Cat  5 ) cable coming into my home directly from the OEM that Hotwire communications installed in my home.
I currently have an old Buffalo Router which seems to be failling after about 10 years, and want to replace it with the Netgear.
Thanks
Message 1 of 2
Guru
Re: Looking to buy the NETGEAR - Nighthawk RAX45 AX4300 WiFi 6 Router
Must have a cable, DSL or Fiber ONT to connect with any external WiFi router that has a RJ45 WAN port connection.
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Thank you.
Message 2 of 2
Discussion stats
  • 1 reply
  • 587 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
