× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Nighthawk RAX45 speedtest only shows half the available bandwidth
vhep
Follower
I just purchased a new Nighthawk AX6 router and have 1gbps up/down fiber connection. When I run a speed test directly on my computer, I get the full 1 Gbps but when I set up the router, and do a speedtest on the router (in the built in software) I only get about 500Mbps. No Qos or Traffic Meter. Any suggestions?
Message 1 of 2
Guru
Re: Nighthawk RAX45 speedtest only shows half the available bandwidth
Don't use the built in speedtest to check speeds?
It rarely saturates gigabit because it chooses the closest server and not the fastests server. And there's no way to choose which server it uses. many speedtest sites struggle to saturate gigabit.
I have gigabit and the speedtest hasn't once maxed out my connection. Only through testing a hardwired pc and trying different speedtest servers or my ISP's server do I max it out.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 676 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
