× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RAX200 Latency issue for all devices if one device uses Wi-Fi Calls
Jimmy_W
Guide
Hi
I have the following setup.
Devices are connected to different bands.
Some devices on 2.4ghz, Some on 5Ghz and one device on 5Ghz with Wi-Fi 6 active.
Now when a mobile phone that is connected on the 5Ghz Standard band receives a call and have the Wi-Fi calls activated on the phone, then latency issue happens across all bands, huge spikes in latency for example on the device that sits on it's own 5Ghz band Wi-Fi 6, latency goes from 45ms to 200ms-800ms up and down until the call is completed.
Tested on iPhone 13 Pro, OnePlus 8 Pro, this issue happens as soon as the phone have Wi-Fi calls activated, turning that function of, no more latency issues. It's clearly something wrong how the RAX200 handles this data on the network.
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 4
microchip8
Master
Re: RAX200 Latency issue for all devices if one device uses Wi-Fi Calls
Do you have Smart Connect enabled?
What firmware version is on the device (not "the latest", a number)
Do you have QoS enabled?
What is the modem in front of the device?
Message 2 of 4
Jimmy_W
Guide
@microchip8
No Smart Connect enabled.
No QoS enabled.
Firmware version:  v1.0.5.132
Message 3 of 4
Jimmy_W
Guide
Bump
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1300 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
