× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
RAX200 V1.0.2.98_1.0.54 issues
javrueda
Initiate
I installed the new firmware yesterday and it has disconnected from the internet 4 times in the last 24 hours. Every time it happens I have to reboot the router manually, this is a bad firmware, be careful. Please, release firmware that are tested thoroughly, this did not happen before the firmware update, in addition please work on the fix, I do not want to be manually reboot the router every 6 hours for a $500 router.
Message 1 of 12
Accepted Solutions
javrueda
Initiate
Re: RAX200 V1.0.2.98_1.0.54 issues
I decided to factory reset the router yesterday night and since then there has not been any issues so far. If anyone has the same issue save your settings first, then factory reset and restablish your settings, it worked for me. Or you can follow LOL2kde solution to revert back to the previous firmware.
Message 8 of 12
All Replies
RajaDaja
Luminary
Thanks for the heads up!
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 2 of 12
wase471111
Apprentice
has worked perfectly for me all day today...
Message 3 of 12
LOL2kde
Betreff: RAX200 V1.0.2.98_1.0.54 issues
I also have problems with this firmware, and after a while the 2.4 and the 5_1 GHz band completely disappears. then only the 5_2 ghz band is still there.
after a reset, it goes again for about 1-3 hours. with the previous firmware ... 88 I put it back on, the problems are gone. So the problem can only be the firmware ... 98!
Message 4 of 12
LD100
Guide
So far, so good...
Message 5 of 12
LD100
Guide
By the bye, it appears the IP V6 address capability is functioning again...at least it shows in my Killer Control Center.
Message 6 of 12
SSgt93
Tutor
I downloaded yesterday for my RAX200 and have had zero issues as well.
Message 7 of 12
javrueda
Initiate
Message 8 of 12
LOL2kde
do you use:
WPA2
or
WPA2 + WPA3 ?
Message 9 of 12
LD100
Guide
Good question--WPA2 + WPA3 on 802.11ax using all three bands.  QoS and guest network are not enabled.
All other wireless features are enabled.
Although my HP Envy 120 printer/scanner is not happy with that and in order to connect it to wifi, I have to change to WPA2.
Always connects to my Killer Wi-Fi6 adapter in desktop on 5GHz low and my smart home thermostat on 2.4 GHz (which has no
problems with WPA3).  Laptop goes to whatever band is least congested.
Still running with V1.0.2.98 and no problems.
Hope this helps!
Message 10 of 12
Kris82
Star
This morning I noticed that the date on the router  ((Nighthawk RAX200) was 2 days off (Saturday, not Monday), though the time was correct. I upgraded the firmware to 1.0.2.98_1.0.54 this weekend and suspect that's the cause, especially since I never saw this problem on the router before the update. I rebooted the router, which fixed the date. I will keep watching in case it goes awry again.
Message 11 of 12
Kris82
Star
I noticed that the time the router shows is wrong too - it shows the time of the last reboot. When I rebooted the router again, the time that displayed was correct, but I expect it and the date to be wrong again as time passes.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 5114 views
  • 7 kudos
  • 7 in conversation
Announcements
Orbi 770 Series
