- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
RAX200 - WPS light continues blinking. Already tried rebooting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX200 - WPS light continues blinking. Already tried rebooting.
Thank you!look forward to the new firmware release.
jim
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Chrisian,
Any update on the Firmware Update to stop the WPS light from constantly blinking?
Just to update, I turned off Smart Connect and have re-setup my router several times now, no change. The WPS light continues to blink. Please provide an update on when the Firmware Update will be made available to fix this issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hopefully this issue will be fixed soon. Bought the RAX200 this week and had to use WPS to setup a printer, on the latest firmware 1.0.2.88 it will blink forever once pressed.
I did fix it temporily by downgrading to 1.0.1.12, this thankfully kept my settings and stopped the blinking. I then upgraded back to 1.0.2.88 and the blinking has stopped while still retaining all my settings. Can't press this again otherwise it will cause it to blink again. Seems this bug only occured since the 1.0.2.88 firmware.
Apart from that small issue I'm very happy with this router coming from the RX8000.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello SpecialK214 - May you update to the latest firmware version and let me know how it turns out.
https://kb.netgear.com/000061900/RAX200-Firmware-Version-1-0-2-88
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Christian,
After seeing your latest post that a new firmware update was available, I updated the firmware per the following steps:
- While on a device connected to the router network, log into the router at http://www.routerlogin.net using the admin user account
- Click on A router firmware upgrade is available.
- Under Firmware Update Assistant, at Do you want to update the firmware?, click Yes
- At The router is updating its firmware and then The router is rebooting. It might take up to two minutes for your changes to take effect., wait for the router to reboot.
After the router rebooted, I followed the steps below:
- Verify that the Firmware Version now indicates V1.0.2.88_1.0.50 in the upper left hand corner
- Click the WPS LED that is solid
- Verify the WPS LED starts blinking
- After five minutes passes, check the WPS LED
Unfortunately, when doing this (and actually waiting over ten minutes on the last step just in case), it continues to blink to where this firmware update does not seem to resolve the issue.
To get the WPS LED back out of a blinking state, I have to do the same workaround as detailed in my previous post, specifically reverting back to FirmWare Version 1.0.1.12 before then again updating to the latest Firmware Version 1.0.2.88.
As far as this thread is concerned, thanks for at least letting us know there was a new firmware update available and checking to see if it might have fixed the problem.
On a more unfortunate customer service note, when checking My Support for my Netgear account, I find that the Netgear case that was opened on 5/16/2020 per the testing I described in my last post indicates a Closed Date of 2020-05-19 10:56:43. Its Communication History is limited to This case has already been closed, please log a new support request if you require further help. After my initial chat session, the only follow up from Netgear I recieved regarding the case was a request for a customer satisfaction survey (which I now realize was triggered by the case being closed) and a reminder about the same customer satisfaction survey.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still blinking after the firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same here, light still blinking:(
jim
- Mark as New
- Bookmark
- Subscribe
- Permalink
just to echo what everyone else is saying, the only way, seemingly to have it not blink incessantly is to factory reset and then restore your settings manually and NOT via a back-up file, which will reintroduce the incessant blibking.
don't forget ypu can use the "soft push button" in WPS Wizard and it works just as effectively. i haven't tried manually restoring the settings, and then using the soft push button for a WPS connect, to see if that reintroduces the bug? anyone?
i'm pretty sure we are not network vulnerable with the blinking, it's just annoying; and don't forget you can turn off all the LED's using the LED on/off switch next to the reset button or from the LED Control settings, if it irritates you that much 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Christian,
I updated my router to the latest firmware 1-0-2-88. No change. The WPS light continues to blink. When will NetGear issue a firmware update to actually resolve this issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please release a new firmware right away! When you push the WPS, the light constantly blinks and doesn't turn off. Does the leave my network open to attack or unauthorized devices to connect? Please fix this right away. Is Netgear even working on this issue? What is a ETA for new firware to get the fix? Just purchased, but may return this unit and go back to Belkin! For the top of the line unit and the very expensive cost of this unit, this model should be trouble free! I have tried most all the attemps by others, but still in the same position of the blinking light. It is incomprehensible how this issue was not found in the development and testing process.
Netgear, your reputation is on the line here!
CPH
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your reply.
I did come accross a setting that gives this option:
"Block all new devices from connecting"
Hopefully this will help with the security issues of unauthorized users.
This setting is located under the advanced tab/security/access control
CPH
- Mark as New
- Bookmark
- Subscribe
- Permalink
i find a fix for this
i got rid of this and got the AmpliFi ALIEN Router so much better and way faster then the rax200
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm also getting the same problem; router is currently on firmware version V1.0.2.88_1.0.50. Looks like there's a new beta version for download - V1.0.2.92_1.0.50_beta - on the Netgear support site. The release notes for it sucks - just says "security fix" and no other details. Hesitant to push this to my router since it's beta and I have no idea what's in it. I'm actually disappointed in the new products from NetGear. I also purchased the EAX80 and having disconnect issues with EAX80 extender. But I digress. These issues are serious which cause core functionalities and security risks. Support is par at best. These problems shouldn't even be happening if these products/firmwares are thoroughly tested before release (serious QA control). And when these problems are reported, they should be fixed immediately, not wait for months on end without any updates. I used to be a fan of Netgear and a huge advocate for their products. I've already invested in these products and can't return them because my return window has passed. Now all I can do is just wait and wait and wait for firmware updates in the hopes that these updates will fix these core issues. If not, I might just consider dumping them for a loss and getting a new router/extender or mesh system from another vendor.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yep! Still waiting for a fix!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just installed the latest firmware update, NO more blinking light!
THANK YOU 🙂
Jim
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes the lastest update stops the blinks WPS light. Although if you push it again, it won't stop. Still Broken.
What......is.....the......hold.....up...?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yikes! What incomptence.... here I thought it was finally fixed.
Jim
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately, although it may fix the blinking light there are issues with that firmware V1.0.2.98_1.0.54. On support to Netgear and they had asked me to do a firmware downgrade and it turns out that the V1.0.2.98_1.0.54 firmware has been pulled by Netgear.
This Router has great performance and range but it's firmware makes Asus Router's look polished and refined. I am lucky i am in the return window, so i think this is the final straw for me, it's going back and Netgear has not only lost a customer but gained a vocal complainer as to the quality of their equipment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yep, mine is installed today with latest firmware. Attempted WPS for an extender and blinking continues.
- « Previous
- 1
- 2
- Next »
