- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Repeated DHCP assignments in RAX43 log
- Mark as New
- Bookmark
- Subscribe
- Permalink
In the router logs there are many repeated DHCP assignments to the same devices in very short spans of time for some reason. In the latest firmware notes it’s mentioned there’s a fix for some DHCP issues in certain environments, and I strongly suspect it introduced new issues. Prior to this week it has run flawlessly for months.
I suppose the next step would be to revert firmware, but I haven’t figured out how to do that yet. I’d appreciate feedback of any other steps to try before that!
*Unable to select Nighthawk AX5 RAX43 in “Associated Products”
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Repeated DHCP assignments in RAX43 log
Is this seen in different browsers?
What devices do you have all connected to the router?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
I recommend setting a new default DCHP IP address range of .100 to .200.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had factory reset both the original Arris modem and Netgear router in addition to many restarts, including disconnecting the power cable for 1+ minutes.
One thing I forgot to mention is that the internet worked consistently via ethernet cable both from the router and modem, even when internet wasn’t being provided through the wifi connection (which still broadcast with 100% signal strength.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Avoid using the combo modem in router mode with the RAX in router mode. If you do, besure to disable the modems wifi radios and use the modems DMZ for the RAX. Or configured AP mode on the RAX router with the ISP Modem being the host router with it's wifi radios disabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problem persists even though it’s assigning new IPs in the correct range, and I don’t think it’s affected by the new modem/router combo as the issue and logs are nearly the same as before. I’ve attached RAX logs from before and after IP range adjustment for reference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
TL;DR
The router is not the problem and the DHCP logs were likely a result of normal reconnection attempts due to imbalanced downstream bonded channel power levels cause by ISP infrastructure issue(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Disabling those logs has resolved about 95% of the problem surprisingly, since CPU usage never showed any strain. Definitely something Netgear should look into (the false positives should have been fixed a long time ago anyway).
It seems the DHCP assignments were just a symptom of these interruptions. I’m going to disable other logs and see if I can iron out the last occasional hangups.
Edit: the ISP’s “fixes” didn’t end up lowering the power level range, which shifted but didn’t get lower in range (~+4 to -8). One tech said it was a problem, the last said anything +10 to -10 is fine… guess the latter was right.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
