× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Why can't I log in to my RAX45 Router to change the wireless channel?
Burdell
Tutor
Anyone know why I can not log in to my Router using the IP adress 192.168.1.1 to change the wireless channel?  The log in gets stuck everytime and is unable to connect.
Im using a macbook.  Does not work using 'Routerlogin.net' either
Message 1 of 4
Guru
Re: Why can't I log in to my RAX45 Router to change the wireless channel?
Have you tried a different browser?
What modem do you have?
Is it a modem/router combo device? It can cause a double nat.
Many times the router will change its default ip address to 10.0.0.1 if it recognizes its in a double nat.
Message 2 of 4
Burdell
Tutor
Hi Plemens...Update on not being able to change wireless channel on my Netgear ax45:
Used my wife's computer..Used Chrome as browser..but what got me in was using the
  10.0.0.1 IP adress. So all is well..Thanks agan Plemens!  You are on it sir.
Message 3 of 4
Guru
Glad it worked!
If you mark it solved, it might help the next person with your issue
Message 4 of 4
Discussion stats
  • 3 replies
  • 761 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
