niwat
Jun 30, 2023Aspirant
raxe300 buy from EU would like to change region to singapore, how to do ?
i order raxe300 from EU and bring router to use in south east asia, i would like to change wireless region from EU to singapore (region selection is gray) i know firmware base on where is the manufacturing of the product. How can i change the firmware and where i can load that firmware?
- microchip8MasterYou can't, AFAIK
The main reason where Netgear must suppress the region settings are the FCC regulations - so models sold in the US.
There is only one firmware for all markets.
What model id does your RAXE300 show on the back: Is it a RAXE300-100NAS (that would be a North American FCC version) or a RAXE300-100EUS? The RAXE300-100CNS is the version for the Chinese market, the RAXE300-100PAS is the version for the Asia-Pacific market.
- niwatAspirant
thanks for your help, but no word on the back side -100nas or -100eus or -100cns or -100pas
it's just say model raxe300 and have address netgear uk
Well possible the manufacturer product designation isn't printed on the device. As you mentioned the Netgear UK mark, its a European model - with the hardware version -100xxx (what could vary) and the market designation -nnnEUS - this visible on the shipping box label only.
Worth a try to tweak the Web UI code as it was suggested before. And hope the change can be applied and saved, different from the FCC models.
Where are you looking to change the region?
The only place where Netgear locks the region is usually North America. Models sold into Europe usually have the option to change the region:
- Advanced
- Advanced Setup
- Wireless Settings
- Region
Or, in some firmware:
- Advanced
- Setup
- Wireless Setup
- Region
In both routers, I see a Singapore option.
- niwatAspirant
it's gray area cannot do anything
Hi
I have bought RAXE300 and RAXE500 from Hong Kong authorized dealer.
RAXE500 can change region code to other Asia Pacific countries, e.g. Japan, Korea, Hong Kong...etc
But the RAXE300 which I bought from Hong Kong with same distributor, it is LOCKED to Europe.
I cannot change the region code. the label at the back is Netgear UK. (RAXE300)
I just found Wifi6E frequency channel in UK is the same as Hong Kong.
Those government blocked reserved frequency is the same in HK and UK.
RAXE500 which don't have Netgear UK label at the back, it do not specify country as RAXE300.
but region locked to Asia Pacific countries. I cannot change it to Europe or USA.
If I want to use ALL frequency in WiFi6E, I can change the region code to Korea in the RAXE500
but seems NO solutions in RAXE300.
Best Regards,
Tiger 🙂
