Orbi WiFi 7 RBE973
Reply
having problem with the vpn connection my ip stays the same
flyaway1999
Tutor
hi, im having a few issues with the vpn. so first it does get connected(i followed all the instructions, downloaded the files etc) but firslty, assigned ip on the openvpn client stays blank, i tried on auto and all websites and home network, and second the vpn clients keeps outputting this
Wed Oct 2 21:59:00 2024 WARNING: Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless "allow-compression yes" is also set.
Wed Oct 2 21:59:00 2024 DEPRECATED OPTION: --cipher set to 'AES-128-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305). OpenVPN ignores --cipher for cipher negotiations.
Wed Oct 2 21:59:02 2024 WARNING: Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless "allow-compression yes" is also set.
Wed Oct 2 21:59:02 2024 DEPRECATED OPTION: --cipher set to 'AES-128-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305). OpenVPN ignores --cipher for cipher negotiations.
i can see  theres a  connection on the bottom but the ip doesnt change which defeats the whole purpose of a vpn. is there a fix for this?
Message 1 of 4
Accepted Solutions
flyaway1999
Tutor
Re: Getting flawless gigabit speed on wireless but grtting 5mbps on wired ethernet
i actually found the problem it was none of those. i had this stupid software on my computer called realtek dragon that was limiting my ethernet to 10gbps.
Message 4 of 4
All Replies
flyaway1999
Tutor
Hi, so I can't seem to understand I get good speed on wifi but wired I'm getting 5mbps on a cat 8 cable and in the 2m5gig port. No power sabing features on the adapter full duplex negotiation etc... what's going on???
Message 2 of 4
CrimpOn
Guru
What a fascinating problem.  There appear to be three obvious components to consider:
  • The Ethernet cable.  Never hurts to "rule  this out" by swapping in a different cable.
  • The router port.  Does the same speed problem exist on all four LAN ports?
    (two 2.5G and two 1G?)
  • The Ethernet adapter. I have seen discussions reporting compatibility issues with specific 2.5G Ethernet adapters.
    (which adapter is this?  running on what platform?  driver firmware?)
    Is there a different Ethernet device that can be connected?
How do the router and the user device report the Ethernet connection?
Perhaps the Nighthawk web interface has something similar to the Orbi "Show Statistics" display which indicates the speed that the router has negotiated for each of the Ethernet ports? (WAN & LAN)  Windows computers display similar information about the Ethernet adapter connection.
Message 3 of 4
flyaway1999
Tutor
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 775 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
