Discussion stats
  • 6 replies
  • 169 views
  • 1 kudo
  • 4 in conversation
Announcements
Top Contributors
Reply
Highlighted
Cell phone calls disconnect when on Wi-fi
I have noticed that if I have my WiFi on my iPhone XS and someone calls , the call gets immediately disconnected. If I try to make a call & the WiFi is on, as soon as someone picks up, the call is disconnected. Not a problem when the WiFi is turned off. Not a problem when I’m on someone else’s WiFi. Thoughts? Some kind of restriction from the Orbi router? (I’ve had this iPhone for almost 2 years and this is a new problem.)
AT&T fiber optic-dumbswitch-Orbi RBK852 with 2 satellites
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 7
Highlighted
Guru
Re: Cell phone calls disconnect when on Wi-fi
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
My Setup (Cable 900Mbps/50Mbps)>CAX80>Orbi RBK50 v2.5.1.16(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK50/RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 7
Highlighted
Master
Do you have "WiFi Calling" enabled on the iPhone?  (not that I "know anything", because I have never used WiFi Calling and do not have an iPhone)
I love my Orbi.
Message 3 of 7
Highlighted
Luminary
And conversly, if you turn wifi calling off, do the calls complete normally?
Message 4 of 7
Highlighted
Exactly. Turn off WiFi, no problem.
Message 5 of 7
Highlighted
Luminary
Not exactly. Sometimes there is a setting messed up that turning that feature off and then back on fixes. Just turning off WiFi would not reset the WiFi calling feature - it would just turn off WiFi on the phone.
Message 6 of 7
Highlighted
Guru
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Message 7 of 7
