Orbi WiFi 7 RBE973
Reply
Selling a Satellite? ax4200 RBR750
MingusTheBugg
Hi,
I bought an Orbi Router and 2 Satellite system. I have a small house, and it was probably overkill. I only need one router and 1 Satellite.
Would I have any issue breaking up the pair of Satelllites, and selling one of the Satellites to a friend (who has an Orbi router)?
Are there any limitations, and can you break up a set, and sell the Satellite?
Thanks,
C
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 5
Mstrbig
Master
Re: Selling a Satellite? ax4200 RBR750
As long as your friend has an AX system you will both be good. Currently, Orbi WiFi 6 Systems are only compatible with Orbi WiFi 6 satellites.
Message 2 of 5
Guru
You can sell the satellite without issues. It should pair with your friends system fine if the systems are compatible.
Message 3 of 5
MingusTheBugg
Thank you. That makes sense. It must be the same Wifi 6 version, but as long as that requirement is met, we should be good.
I’ll check with my buddy just to make sure.
Thanks!
Message 4 of 5
Guru
Please post about any Orbi AX questoions or information over in the Orbi AX Forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Enjoy.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 732 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
