- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Pro (SRK60) Wifi problems with online gaming
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have a fiber-optic internet connection at home (modem is CTS FWR5-3105). Netgear Orbi Pro (SRK60) router is connected to bridge mode port of fiber-optic modem. If I try to play online games (like Counter-Strike, Fortnite, many car racing games etc), I get problems to connect to game server. If I succesfully join to the server, the game lags a lot and it is particularly impossible to play.
I didn't have these problems when I had same computer and Orbi system with 4G-connection (router was Huawei B593). Everything works great when using Wifi from fiber-optic modem, too. There is neither problems when connecting my computer to Orbi router with cable. The only problem is Orbi wifi with fiber-optic connection. And the problem is with games, not with Internet browsers or video streams (Youtube, Twitch etc). Connection speed is good (ping 15, download and upload speed maxium of my connection = 200 Mbps)
Firmware is up-to-date, wifi channel is free (no competative 5 GHz) etc. I have made factory reset. Problem exists with and without Satellite. Orbi is in router mode.
Is there some wifi setting that I should change?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Pro (SRK60) Wifi problems with online gaming
Welcome to the community! 🙂
There might be ports that needs to be opened for the games you play.
Are you playing games using a PC?
What are the wireless settings configured on the SRR60?
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried this solution a couple of months (1 year?) ago, but I think it was not possible to open many enough for Counter Strike for example. And why everytning was fine with the Same SRK60 and 4G connection? Ports for CS:GO are
- TCP: 27015-27030,27036-27037
- UDP: 4380,27000-27031,27036
Yes. Windows 10.
What do you mean especially?
- 2,4 Ghz channel automatic (Auto ( 5(P) + 9(S) )), 5 Ghz 36 (tested also other choices) (36(P)+40+44+48)
- WPA2-PSK [AES]
Router information
- DHCP enabled
- Router-mode
Advancedd settings attached (I didn't manage to add photo in the text)
Does this help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@tonator wrote:I didn't have these problems when I had same computer and Orbi system with 4G-connection (router was Huawei B593). Everything works great when using Wifi from fiber-optic modem, too. There is neither problems when connecting my computer to Orbi router with cable. The only problem is Orbi wifi with fiber-optic connection.
When I get you right, two alternate Internet connections work or worked fine on the vey same Orbi Pro GbE WAN port - and the issue is "just" with this bridged Internet port on the CTS FWR5-3105? hmm...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Correctly. I also have turned off CTS 5 GHz wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @tonator
Are you using EU SKU?
Could you please share the debug logs? Go to https://<ip address of Orbi Pro>/debug.htm
Click on start capture.
Recreate the issue.
Save the debug logs.
Upload debug into google drive or similar and send me link via PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
@RaghuHR wrote:Hi @tonator
Recreate the issue.
Hi @RaghuHR
Yes, I'm using EU SKU.
I sent a private message that includes link to debug log.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It sounds like you may be experiencing issues with your Orbi Pro router and fiber-optic internet connection when playing online games like car parking multilayer. While your internet speed is good, the lag and difficulty connecting to game servers suggest that there may be some settings that need to be adjusted on your router.
One thing you could try is to prioritize gaming traffic on your network by enabling Quality of Service (QoS) on your Orbi Pro router. This will ensure that your gaming traffic is given priority over other types of traffic on your network.
Another setting you could try adjusting is the channel width for your router's 5 GHz band. Some gaming devices may have trouble connecting to wider channels, so you could try adjusting the channel width to a smaller setting to see if that improves your connectivity.
Finally, it's possible that there may be some interference in your area that is affecting your wifi signal. You could try using a wifi analyzer app to check for any competing wifi signals on the same channel as your Orbi Pro router and adjust your channel accordingly.
