Orbi WiFi 7 RBE973
Orbi Pro SRK60 over two-floor house connected via Ethernet
Marco-F
I'm considering buying the kit of 6 SRK60 Orbi Pro to create a unique WiFi mesh over two floors.
I can make use of Ethernet cable to connect the 6 units among them. In fact, not all the rooms are reachable via WiFi from the Orbi Pro router.
Question: can I use the Ethernet port to connect the satellite in a mixture of star and daisy-chain design?
I'm able to connect only two satellites directly to the router via cable. The other three satellites will be connected via cable, one after the other.
Here below the connection design. All connection among units are via Ethernet cable.
        Orbi Sat4
Orbi Sat1===Orbi Router===Orbi Sat2===Orbi Sat3===<
        Orbi Sat5
The Sat 3 is connected to thre other ones (Sat2, Sat4 and Sat5).
A couple of Sat will then have other IP items connected like IP cameras.
Would this be possible?
Model: SRK60B06|Orbi Pro Tri-Band Business WiFi System
Message 1 of 4
Accepted Solutions
JohnC_V
NETGEAR Moderator
Re: Orbi Pro SRK60 over two-floor house connected via Ethernet
@Marco-F,
As long as it will not over 8 satellites. It should work fine 🙂
Please close the thread by clicking the "Accept as solution".
John
NETGEAR Community Team
Message 4 of 4
All Replies
JohnC_V
NETGEAR Moderator
@Marco-F,
Yes! That's possible either you connect it via cable or wireless. As long as it will not over to 8 satellites and everything will be good.
John
Message 2 of 4
Marco-F
Thanks for confirming.
I would just add that the Ethernet backhaul can be designed also as a mixture of star and daisy-chain, right?
Message 3 of 4
JohnC_V
NETGEAR Moderator
@Marco-F,
John
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2271 views
  • 0 kudos
  • 2 in conversation
Announcements
