Orbi WiFi 7 RBE973
Orbi Pro SRR60 wired pps?
BobTRF
What is the SRR60's packets per second forwarding capacity between its LAN and WAN ports, specifically small packets (RTMP uses 128 bytes)?
Model: SRK60B05|Orbi Pro Tri-Band Business WiFi System
Message 1 of 5
Accepted Solutions
MrJoshW
NETGEAR Expert
Re: Orbi Pro SRR60 wired pps?
Speaking to engineering about this and based on testing the results were a packet size of 128bytes had a throughput of 100mbps and a packet size of 1460bytes had a throughput of 940mbps. Results may varie depending on current network traffic and cabling.
Message 3 of 5
All Replies
DaneA
NETGEAR Employee Retired
@BobTRF,
Welcome to the community! 🙂
I have already inquired your concern to the higher tier of NETGEAR Support.  I will post here once I got a feedback.
DaneA
NETGEAR Community Team
Message 2 of 5
MrJoshW
NETGEAR Expert
Message 3 of 5
BobTRF
Thank you @MrJoshW for that throughput number, for both small and large packets.
If my math is right, does that mean we should expect it to handle about 97K small TCP packets per second?
Message 4 of 5
MrJoshW
NETGEAR Expert
That is correct.
Message 5 of 5
Discussion stats
  • 4 replies
  • 2883 views
  • 1 kudo
  • 3 in conversation
Announcements
