Orbi WiFi 7 RBE973
Reply
Orbi SRR60 Wifi not showing up during setup
dnaz_1824
Follower
I keep trying to set up my orbi router but during the stage of setup where my orbi app is supposed to see the orbi's wifi signal, even though everything has been working as expected until that point, there is no signal to be seen. I've reset my modem and routers countless times and done the setup process all the way through multiple times just for it to stall out at that step, any suggestions would be greatly appreciated.
Message 1 of 2
quagmire1
Luminary
Re: Orbi SRR60 Wifi not showing up during setup
The SRR60 doesn't use the Orbi app.  The Pro series Orbi systems use Netgear Insight.
This article should help:
https://kb.netgear.com/000053872/How-do-I-set-up-my-Orbi-Pro-WiFi-System-to-work-with-Insight?langua...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 913 views
  • 0 kudos
  • 2 in conversation
Announcements
