- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Trying to sync SXS80 with another router than the one iit was delivered with
- Mark as New
- Bookmark
- Subscribe
- Permalink
HI. I need 5 AP units for full coverage across our facility, so i purchased 2 orbi 6000 3-packs, looking to use only the satelites from the second pack together with the first pack. Got the first pack up and running, but whatever i do, i cannot get the satelites from the second 3-pack to sync with the router of the first.
when running the sync in the admin browser, the magenta ligt comes on after a while. The satelite becomes visible with SSID that was preconfigured as part of the second pack. The behaviour is conistent for both for both satelites from the second pack
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Trying to sync SXS80 with another router than the one iit was delivered with
try hardwiring the satellite into the router and syncing it. (give it a bit).
Make sure they're on the same firmware.
when you disconnect it, it should stay sync'd
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @pellison ,
Please follow below mentioned steps, it will help you to add satellites wihtout any issue
Press the reset button in the second 3-pack's satellite, after satellite reboot and booting up around 3 mins, running the sync in the admin browser and prepss the wps button in satellite, it only allows to connect one satellite each time, please try it in each second 3-pack's satellite.
Because we don't know what configurations are there in second 3-pack's satellites, so reset is the better option to make sure everything works well.
Thanks,
Basavaraj
- Mark as New
- Bookmark
- Subscribe
- Permalink
