- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
App confusion
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is anyone here?
I have a CBR750 modem/router and have the upgraded VPN via the Bitdefender mobile app. After online chat with NG, I uninstalled that VPN and went through the VPN installation via the Armor app (per online chat direction). So yes, I have paid twice for the VPN.
See the lower row on the following screen grab. Which apps work together? If I click on the VPN for Netgear and turn on protection, and then click on the Armor app, that app says I'm not protected. If I turn on protection in that app, then the VPN for Netgear app says I'm not protected. I also screen grabbed the VPN configurations from settings. Why are there five of them?
Thanks in advance for any help!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 and @michaelkenward You are the only people to respond to me. Thanks. As I mentioned earlier, I did post to one of your recommended forums. Here's the result: https://community.netgear.com/t5/NETGEAR-Armor/App-confusion/m-p/2162736/highlight/false#M5627
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: App confusion
As you are asking about the CBR750 and Armor you might get better luck asking in the appopriate sections rather than a zone given over to Nighthawk WiFi Routers.
NETGEAR Armor - NETGEAR Communities
Orbi with Built-in Cable Modem - NETGEAR Communities
Your issues are unlike the generic stuff that can be answered anywhere.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: App confusion
Thanks! I'll do that.
BTW, I did try to enter cbr750 in the "Model" window (to help the community give the best answers) but that's not allowed and the window defaults to Knighthawk.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: App confusion
@michaelkenward thanks again, and I don't have any problem with this being deleted from this thread. I can't delete it myself, right?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: App confusion
Don't worry about it. If Netgear makes it hard for people to work out where to post queries why should we worry when things go astray?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: App confusion
Thanks, I copied it to the first link that @michaelkenward listed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: App confusion
Thats ok. Were trying to get NG to do some forum community updates. Forums needs alittle work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: App confusion
I'm not trying to get Netgear to do anything. It is Netgear's community. I understand how difficult it is to get something like this changed. (It is a lot harder than you might think, especially when you use third party software.) Better to live with the world as it is than to confuse and annoy everyone by getting all anal retentive.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
