Orbi WiFi 7 RBE973
Reply
CBR750 & CBK 753, WILL THE ROUTER IN THE 753 SYSTEM BECOME A SATELITE WHEN USED WITH CBR750 MODEM.
riq90210
My current modem died out looking for a replacement. I have the CBK 753 system, My thinking was maybe add the CBR750 and have the CBK 753 system be ALL satelites or will the CBK router not be utilized.
Message 1 of 4
Guru
Re: CBR750 & CBK 753, WILL THE ROUTER IN THE 753 SYSTEM BECOME A SATELITE WHEN USED WITH CBR750
If you meam the RBK753 system and the RBR750 from that kit, then NO. RBRs only work as routers or in AP mode.
Message 2 of 4
riq90210
Yes, that was what I wanted to know the rbr750 from the kit as a satélite with the addition of the cbr 750 as the new router and modem. Thanks, I thought maybe it had the option to change it as an extender satelire
Message 3 of 4
Guru
Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1253 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
