- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot login to webpage as Admin any more
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have a new Orbi mesh router that is all setup and working.
I had to setup up some NAT stuff, so went into the devices web page on my computer, and also changed the admin
password to something else while I was there.
I logged out and logged in with the new password fine. Several days latter I tried to login, and it would not accept
my login password or the default one.
I tried entering 3 invalid passwords so that it would ask the security questions, but nothing, just back to the login page.
How do I fix this? If I have to do a factory reset, will that remove the settings entered by my Internet Provider?
This seems to be a common problem with this router.
I can get in via the phone app, but not sure if I can change the admin password there to fix.
EDIT: Some other detail. A day back I had enabled the guest network for WiFi, then decided not to use it and disabled it again, now I notice that even with a wired ethernet connected login attempt, I see to login users "admin" and "guest"
The guest login is there even after disabling it. I cannot login in to either though.
Seems like a fault with the unit.
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, I fixed this with a reboot of the Orbi ..
So it seems, it is a firmware bug, to my mind it should not perform like that, I would not like my customers to have to go though that in one of my net connected products.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cannot login to webpage as Admin any more
What model Orbi system do you have?
What browser are you using? This happens in other browsers like MS Edge or Firefox or Opera?
Be sure to clear out all browser caches and saved PW profiles with in the browser.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi Wifi 6 AX1800 RBR350
EDIT: found out via android app v4.20.0.4
? No idea .. provided by Chorus New Zealand
Brave
No difference
- Mark as New
- Bookmark
- Subscribe
- Permalink
This may be ambiguous.
- If this refers to the public IP address, subnet mask, and DNS entries created when the Orbi uses DHCP to connect to the ISP, then "yes". Every time the Orbi connects those settings will be created by the ISP. This is how the ISP sometimes changes the public IP address of customers who have dynamic IP assignments (most of us).
- If this refers to ISP settings entered by the user to connect to the ISP, such as user name and password, then a Factory Reset will erase these and the user must enter them agaiin.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
