Orbi WiFi 7 RBE973
Reply
Guest Password on RBR750 Orbi Doesn't Work
wagnermba
Guide
Hi: I set a guest password for my RBR50 Orbi Router -- using Orbi app on iPhone and also from the web admin page.  But, whenever I try to login to it via phone or computer, it says "incorrect password."  I've confirmed I'm using the correct one (that includes a cap letter, three numbers and two punctuation marks).  I changed the Guest WiFi Settings security method from WPA2-Personal to WPA/WOA2-Personal and neither made a difference.  I also rebooted the router via the Orbi app. Any other suggestions?  Thanks!
Message 1 of 4
Accepted Solutions
Guru
Re: Guest Password on RBR750 Orbi Doesn't Work
What devices do you have connected?
What special characters are you using?
As a test, does Password123 work if you set this using the RBRs web page?
Message 2 of 4
All Replies
Guru
Message 2 of 4
wagnermba
Guide
Thank you.  By removing special characters (exclamation marks) it works great.  Thanks!
Message 3 of 4
Guru
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 705 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
