- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How can I turn off auto updates on an Orbi RBR750?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having random router reboots of my Orbi RBR750 that I suspect is related to auto firmware updates. Does the router do auto firmware updates? Any ideas how to turn off auto firmware updates?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would review this:
Current released FW has known problems for lots of users. This pre-release seems to have helped get better results.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How can I turn off auto updates on an Orbi RBR750?
Something Orbi doesn't support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could you please provide more detail. Orbi routers check for firmware update at regular intervals (multiple times per day for some models). Have you observed that the firmware version actually changes when there is a random reboot. Or, do you suspect that the process of looking for firmware updates itself is causing the router to reboot? If that were the case, then every Orbi router would be rebooting multiple times per day.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The log file just indicates a restart from what I can tell.
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hope this helps.
Well, it helps indicate (to me) that firmware update is not the cause of the spontaneous reboots. There are other posts in the forum describing issues with the 750 product. (I do not own one, and thus have not watched those posts closely, but I have an impression that there might be a test version of firmware that is being tried by some users. Perhaps that might be a more useful direction than trying to block firmware updates.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Firmware version: V4.6.5.14_2.0.54
- I have Verzion FIOS 1000↓/1000↑ service with their modem/ONT but I do not have access to the device to get the model #
- Building is 80' long and narrow. Router is located 1//3 distance from one end on main floor
- Distance between routers and satellites are at least 30'
- One router is in the basement
- One router is upstairs
- One router is at other end of house connected via ethernet cable because it is too far from the router or other satellites to get a decent signal
- 42 devices connected
It is possible that the firmware update checks are not th eproblem, but I am at my wits end as to what it might be.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Many thanks for the link! I have upgraded my FW to that version. Fingers crossed it will address the random reboot issue and not introduce others I care about 😉
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
[Time synchronized with NTP server] Saturday, Feb 05,2022 10:03:16
[Internet connected] IP address: 96.227.94.181, Tuesday, Dec 07,2021 02:45:41
[Initialized, firmware version: V4.6.7.5_2.1.7] Tuesday, Dec 07,2021 02:45:37
[DHCP IP: (192.168.xx.xx)] to MAC address 24:F5:A2:xx:xx:xx, Saturday, Feb 05,2022 10:03:54
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is NTP configured correctly and time zone set?
I would clear the router logs then take a look again in a few days or if you notice something.
Have you noticed anything since the FW update?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- NTP was configured as default to Netgear NTP server. I've switched to NIST-a.
- TZ was set correctly
- I had not encountered any other issues
- Will clear logs and review periodically
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
