- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Latest Firmware (V4.6.3.16) Broken My Internal Static Routes To Site To Site Tunnel Device
- Mark as New
- Bookmark
- Subscribe
- Permalink
The latest firmware update has broken my static routes to my
I have the Orbi serving the internet / wifi for my house. For business purposes I have a Fortigate 30E that has one port on the internal network, and a separate one to the WAN. Whenever I request a specific subnet the Orbi used to take those requests and forward them to my Fortigate. It worked like a charm for as long as I have had this Orbi (and my previous Orbi as well.. I would say 3 years)
Then out of nowhere the Orbi auto updates to this latest firmware and it broke. I cannot get it to downgrade to another firmware or anything to happen. How do I get this fixed? I even tried to buy support from the website but it says I am in the wrong country (I am US). Are there beta firmwares to try? I dont even know how to report this to the devs to make sure it gets fixed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latest Firmware (V4.6.3.16) Broken My Internal Static Routes To Site To Site Tunnel Device
Is Armor or Smart Parental controls enabled?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I have done a factory reset and setup from scratch.
I do not use armor or parental controls.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can down grade the RBR normally, however to downgrade the RBR, follow this:
Can you use your Fotigate to block update services for Orbi?
TCP port 443 (HTTPS): http.fw.updates1.netgear.com
TCP port 21 (FTP): updates1.netgear.com
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks! Where do I download a lower firmware and how do I stop automatic updates?
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://www.netgear.com/support/
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you have the 7 series Orbi:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unforetunately I am the RBR850
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, hopefully NG will be releasing someting soon for the 8 series.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It has been a few days and nothing released. Is there any beta firmware I could try that you know of?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately nothing.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
