Orbi WiFi 7 RBE973
Reply
Netgear AX Orbi - Mixing Satellites?
Validus
Luminary
I'm wondering if it would still be possible to use previous satellites from the Netgear AX6000 (RBK853) upon the newer Netgear AXE11000 (RBKE963), if upgrading? Ideally sharing the same Wifi network, rather than being separate from each other.
I understand performance degrading between them, but could the backhaul connection be linked? If so, is it wireless between the different satellites or would they need to be ethernet chained together to make the change over?
Message 1 of 3
Guru
Re: Netgear AX Orbi - Mixing Satellites?
Officially NG doesn't support however some of our testing has reported 8 series connecting to 9 series orbi systems.
Message 2 of 3
Guru
I don't have the 8 series but I have a 9 and a 7. When I hardwired my 7 series satellite into my 9 it worked on 1 or 2 of the firmware. Not sure about the current version
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 591 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
