- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear RBKE962 satellite keeps disconnecting intermittently
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the RBKE962 satellite positioned in my lounge room, which is connected wirelessly to my TV, streaming box and soundbar all in the same room via 5ghz.
The main router is down the hallway.
every now and then I will check my lounge room devices (TV, streaming box, soundbar) on the Orbi app, and they connect back to the main router down the hallway which has a poor 2.4ghz signal. it seems like the satellite disconnects intermittently which forces my lounge devices to revert back to the main router signal.
to get my lounge room devices connected back to the satellite, I have to power cycle them (TV, streaming box, soundbar) , then they will reconnect to the satellite straight away.
the satellite is connected via wireless backhaul and the connection says 'GOOD' in the orbi settings.
The satellite is about 10m away from the main router. Am using the latest firmware V7.2.6.31.
Can anyone suggest any possible solutions so my devices stay connected to the satellite?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear RBKE962 satellite keeps disconnecting intermittently
MIght try moving things around a little.
Many devices have their own roaming protocol and they'd "prefer" to be connected to the primary router if its close enough. Maybe the 10m isn't far enough away for them to choose the satellite over the primary router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Somehow the Satellite is dropping connection intermittently. This is the issue.
I think I might need to connect the satellite via wired backhaul.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
How long has this been happening?
- Mark as New
- Bookmark
- Subscribe
- Permalink
House is not that big. Not sure exact square meters.
I noticed it when my YouTube on my LG TV started buffering and getting slow connection. Wondering why. I was checking out the Orbi app and seeing what was connected to the satellite.
Then I saw that my lounge devices were connecting to the main router, and not the satellite.
Once again, when I power cycle my lounge devices they immediately connect to the Satellite and have a super fast connection. But I noticed after a few days something happens and then my devices connect to the main router.
Something is causing the Satellite to disconnect. And I have actually noticed it sometime in the morning where I would see the Satellite flash with a blue light , then eventually the blue light would turn off.
My RBKE962 is fairly new. Only had it for about a month.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Might bring the RBS in just a bit closer to the RBR and see?
FYI, v.31 FW hasn't been good for users, you might downgrade the system to .21 on the RBS first then RBR lastly and then factory reset and setup from scratch and check for this issue. v.21 is most stable version to date.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Or would setting up WIRED backhaul fix it.
Lucky I saw the satellite flashing blue early one morning. That confirms to me it’s disconnecting and reconnecting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Major-Firmware-7-2-6-31-issues/m-p/...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Downgrade using this process in this linked PDF:
RBS first, then RBR lastly.
Factory reset using this PDF process afterwards:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok I've now downgraded to FW .21 and also done a factory reset on both RBR and RBS. Will see if this fixes the issue. thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
BE SURE to DISABLE the auto update on the RBR under Advanced tab/Admin/FW update. Or the system will re-update back to v.31. 🙄
- Mark as New
- Bookmark
- Subscribe
- Permalink
yea I've already done that
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
