- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI CBR750 requires manually releasing/renewing the IP
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have Netgear Orbi CBR750 with RBS750 satellite.
I own this for two month now.
Four days ago, it started dropping internet every 1.5 hours.
Rebooting the router would bring the internet back.
I called Xfinity, the tech came by and he checked the line all the way to the router. He showed me all the reading he got, the gain, the frequencies test and it all looks green. So it is not the cable.
After some digging, I noticed that 1.5 hours corresponds to the Lease Expires time that is present on the Connection Status page.
So I tried hitting Release and than Renew buttons once the internet went down - and that would bring the internet back.
As of right now, I am going to the Connection Status page and doing the release/renew every 1.5 hours.
I am not sure what happened and why it started doing it. It was fine for two months. I didn't update the firmware.
I tried setting up the static IP - it didn't help. It still dies after 1.5 hours.
Any help would be appreciated.
Logs:
[DHCP IP: (192.168.77.3)] to MAC address AC:3C:8E:00:7A:E7, Friday, Oct 22,2021 13:00:53 [DHCP IP: (192.168.77.14)] to MAC address 3E:C8:09:FA:E3:B8, Friday, Oct 22,2021 12:42:23 [DHCP IP: (192.168.77.9)] to MAC address CE:25:AD:5D:D5:9D, Friday, Oct 22,2021 12:40:53 [DHCP IP: (192.168.77.2)] to MAC address AC:3C:8E:00:76:95, Friday, Oct 22,2021 12:18:41 [DHCP IP: (192.168.77.17)] to MAC address 6C:CD:D6:E6:EB:8A, Friday, Oct 22,2021 12:15:38 [Internet connected] IP address: 98.41.205.35, Friday, Oct 22,2021 11:59:44 [Internet disconnected] Friday, Oct 22,2021 11:59:42 [DHCP IP: (192.168.77.14)] to MAC address 3E:C8:09:FA:E3:B8, Friday, Oct 22,2021 11:59:28 [Internet disconnected] Friday, Oct 22,2021 11:59:18 [DHCP IP: (192.168.77.5)] to MAC address F4:5C:89:B1:98:4B, Friday, Oct 22,2021 11:54:02 [DHCP IP: (192.168.77.17)] to MAC address 6C:CD:D6:E6:EB:8A, Friday, Oct 22,2021 11:48:38 [DHCP IP: (192.168.77.17)] to MAC address 6C:CD:D6:E6:EB:8A, Friday, Oct 22,2021 11:48:25 [DHCP IP: (192.168.77.17)] to MAC address 6C:CD:D6:E6:EB:8A, Friday, Oct 22,2021 11:44:01 [DHCP IP: (192.168.77.17)] to MAC address 6C:CD:D6:E6:EB:8A, Friday, Oct 22,2021 11:43:33 [DHCP IP: (192.168.77.5)] to MAC address F4:5C:89:B1:98:4B, Friday, Oct 22,2021 11:43:33 [DHCP IP: (192.168.77.17)] to MAC address 6C:CD:D6:E6:EB:8A, Friday, Oct 22,2021 11:43:24 [DHCP IP: (192.168.77.3)] to MAC address AC:3C:8E:00:7A:E7, Friday, Oct 22,2021 11:43:23 [DHCP IP: (192.168.77.2)] to MAC address AC:3C:8E:00:76:95, Friday, Oct 22,2021 11:37:42 [DHCP IP: (192.168.77.3)] to MAC address AC:3C:8E:00:7A:E7, Friday, Oct 22,2021 11:32:57 [DHCP IP: (192.168.77.5)] to MAC address F4:5C:89:B1:98:4B, Friday, Oct 22,2021 11:26:46 [DHCP IP: (192.168.77.2)] to MAC address AC:3C:8E:00:76:95, Friday, Oct 22,2021 11:15:44 [DHCP IP: (192.168.77.17)] to MAC address 6C:CD:D6:E6:EB:8A, Friday, Oct 22,2021 11:05:01 [DHCP IP: (192.168.77.17)] to MAC address 6C:CD:D6:E6:EB:8A, Friday, Oct 22,2021 11:04:36 [DHCP IP: (192.168.77.17)] to MAC address 6C:CD:D6:E6:EB:8A, Friday, Oct 22,2021 11:04:25 [DHCP IP: (192.168.77.17)] to MAC address 6C:CD:D6:E6:EB:8A, Friday, Oct 22,2021 11:03:31 [DHCP IP: (192.168.77.5)] to MAC address F4:5C:89:B1:98:4B, Friday, Oct 22,2021 11:03:30 [DHCP IP: (192.168.77.17)] to MAC address 6C:CD:D6:E6:EB:8A, Friday, Oct 22,2021 11:03:24
Firmware Version for the modem is V4.6.3.6_2.0.48. I have updated the satellite firmware today to V4.6.3.16.
Event log screenshot is attached.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI CBR750 requires manually releasing/renewing the IP
Please post a copy and paste of the modems connection status page.
Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
Please do not post MAC addresses in public forums.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Connection Status page screenshot is attached.
There are no splitters. I am using good quality coax cable. I tried powering off and on.
How do I make sure ISP provisions the modem correctly?
- Mark as New
- Bookmark
- Subscribe
- Permalink
There should be a connections status page silimar to this:
Cable Connection
Cancel Apply
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
837000000
Startup Procedure
Procedure Status Comment
Acquire Downstream Channel 837 MHz Locked
Connectivity State OK Operational
Boot State OK Operational
Security Enabled BPI+
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1 Locked 256 QAM 31 837000000 Hz 0.1 dBmV 37.4 dB 0 0
2 Locked 256 QAM 1 651000000 Hz -1.6 dBmV 36.6 dB 0 0
3 Locked 256 QAM 2 657000000 Hz -1.6 dBmV 36.6 dB 0 0
4 Locked 256 QAM 3 663000000 Hz -1.3 dBmV 36.8 dB 0 0
5 Locked 256 QAM 4 669000000 Hz -1.3 dBmV 36.7 dB 0 0
6 Locked 256 QAM 5 675000000 Hz -1.1 dBmV 36.7 dB 0 0
7 Locked 256 QAM 6 681000000 Hz -0.8 dBmV 37.0 dB 0 0
8 Locked 256 QAM 8 693000000 Hz -0.5 dBmV 37.1 dB 0 0
9 Locked 256 QAM 9 699000000 Hz -0.2 dBmV 37.3 dB 0 0
10 Locked 256 QAM 10 705000000 Hz -0.2 dBmV 37.0 dB 0 0
11 Locked 256 QAM 11 711000000 Hz 0.0 dBmV 37.1 dB 0 0
12 Locked 256 QAM 12 717000000 Hz 0.4 dBmV 37.4 dB 0 0
13 Locked 256 QAM 13 723000000 Hz 0.3 dBmV 37.1 dB 0 0
14 Locked 256 QAM 14 729000000 Hz 0.6 dBmV 37.1 dB 0 0
15 Locked 256 QAM 15 735000000 Hz 0.9 dBmV 37.3 dB 0 0
16 Locked 256 QAM 16 741000000 Hz 1.0 dBmV 37.3 dB 0 0
17 Locked 256 QAM 17 753000000 Hz 1.1 dBmV 37.5 dB 0 0
18 Locked 256 QAM 18 759000000 Hz 1.0 dBmV 37.5 dB 0 0
19 Locked 256 QAM 19 765000000 Hz 0.7 dBmV 37.4 dB 0 0
20 Locked 256 QAM 20 771000000 Hz 0.8 dBmV 37.6 dB 0 0
21 Locked 256 QAM 21 777000000 Hz 0.7 dBmV 37.7 dB 0 0
22 Locked 256 QAM 22 783000000 Hz 0.6 dBmV 37.7 dB 0 0
23 Locked 256 QAM 23 789000000 Hz 0.7 dBmV 37.8 dB 0 0
24 Locked 256 QAM 24 795000000 Hz 0.5 dBmV 37.7 dB 0 0
25 Locked 256 QAM 25 801000000 Hz 0.4 dBmV 37.5 dB 0 0
26 Locked 256 QAM 26 807000000 Hz 0.5 dBmV 37.7 dB 0 0
27 Locked 256 QAM 27 813000000 Hz 0.5 dBmV 37.6 dB 0 0
28 Locked 256 QAM 28 819000000 Hz 0.1 dBmV 37.3 dB 0 0
29 Locked 256 QAM 29 825000000 Hz 0.4 dBmV 37.6 dB 0 0
30 Locked 256 QAM 30 831000000 Hz 0.2 dBmV 37.5 dB 0 0
31 Locked 256 QAM 32 843000000 Hz 0.0 dBmV 37.4 dB 0 0
32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
1 Locked ATDMA 5 5120 Ksym/sec 22000000 Hz 31.5 dBmV
2 Locked ATDMA 1 5120 Ksym/sec 36000000 Hz 32.8 dBmV
3 Locked ATDMA 2 5120 Ksym/sec 29000000 Hz 31.3 dBmV
4 Locked ATDMA 6 2560 Ksym/sec 16000000 Hz 33.3 dBmV
5 Not Locked Unknown 0 0 0 0.0 dBmV
6 Not Locked Unknown 0 0 0 0.0 dBmV
7 Not Locked Unknown 0 0 0 0.0 dBmV
8 Not Locked Unknown 0 0 0 0.0 dBmV
Downstream OFDM Channels
Channel Lock
Status Modulation /
Profile ID Channel
ID Frequency Power SNR /
MER Active Subcarrier
Number Range Unerrored
Codewords Correctable
Codewords Uncorrectable
Codewords
1 Locked 0 ,1 ,2 33 547000000 Hz -3.82 dBmV 36.6 dB 1108 ~ 2987 64457020 52608446 0
2 Not Locked 0 0 0 Hz 0 dBmV 0 dB 0 ~ 4095 0 0 0
Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power
1 Not Locked 0 0 0 Hz 0 dBmV
Extended Upstream Transmit Power
Current System Time:Sat Oct 23 13:44:57 2021
System Up Time:02:07:41
- Mark as New
- Bookmark
- Subscribe
- Permalink
Got it. Here you go.
Frequency Start Value | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Starting Frequency | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Downstream OFDM Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Upstream OFDMA Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Current System Time: Sat Oct 23 12:52:23 2021 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
System Up Time 1 days 02:01:52 |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great.
Do you have a snippet of the Events Log page as well?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
One item you need to ask your ISP about:
These shouldn't be seen in the logs I believe. Maybe why the CBR can't get a seamless connection and can't get a IP address seamlessly from the ISP. The ISP needs to ensure the CBR is getting the config file correctly. Have them check the events log on the CBR as well.
Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11" |
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
My system just randomly started working. I assume something was up on the Xfinity side. Sorry I don't have any details, I honestly have no idea why it started working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would presume the ISP had done someting on there side. Most of the time this is a ISP signal issue. If the signals and configuration are not done well or with in specs on the ISP side, makes it hard for ANY modem to work right.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please post a copy and paste of the modems Connection Status page and Event Log page.
@Triggs21 wrote:
Thats interesting. Im having the same issue i did before my rma. This model still will not stay connected to xfinity without dropping connectivity. Is there anything I can do to verify isp signal problem? Xfinity has been here several times verifying the signal. Interestingly enough once I connect my older cbr (docsis 3.0) it works fine no disconnects no issues... help
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Current System Time: Sun Oct 31 16:08:44 2021 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
System Up Time 00:25:22 |
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be aware the event log may show inconsistancys due to me unplugging the router and switching coax from the splitter now directly plugged in (no splitter) to see if that makes a difference with dropping internet service
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, Please post a Event log after a while of the CBR being online with out any wire changes.
The Power on the status page maybe too high.
Mines at 0.1dbm range or -1.#Dbm on a few channels on my cable modem.
You might ask the ISP to maybe turn down the power to the modem some.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And I am back to manually releasing/renewing IP again. Same things as was described in the initial post.
Horrible experience. Especially knowing that the modem I bought is very expensive.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Plus i am a IT technician so if I cant figure it out im just left to assume we all purchased a **bleep** model orbi. This is my Rma that came shipped with a totally different firmware and im still having the same connection issues that everyone else describes, amazon is flooded with negative reviews on this model orbi as well.
My older Rbk docsis 3.0 orbi works completely fine with no issues on the same coax line.
Technically I shouldn't have to do or change any settings to get this new one to work stable, it should work as advertised just like it did when i first bought it 6 months or so ago.
We dont expect something to just stop working reliably after afew months of usage, especially from a company ive never had an issue with.
Is this new firmware gonna save my 600 dollar paperweight??
Sorry for the rant just so hard to believe there is no saving this extremely expensive setup!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you updated to v8 yet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have updated to the new V4.6.5.8 firmware, and it still drops every 1.5 hours. I am opening a ticket with Netgear to see if maybe they can help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Called Netgear support.
They told me to change the MTU size to 1486, but they couldn't explain why I should do it.
They told me to update CTS/RTS Threshold to 2347.
And they told me to update wireless channels to the highest number for each channel.
They told me this will fix my issue, which it will not. The issue lays somewhere else other than just tweaking the above.
I will wait another hour for the internet to drop, and will call support again hoping they will take me to the Tier 2 support.
