6172crew
Jan 14, 2021Guide
Orbi 753S (costco) and the amazon echo or google dot
I have seen a few others having issues with getting the smart speakers to play, or stream but none of the issues are mine and I see no fixes.
I have fiber to the prem, 250mbps and use my Orbi for wifi only. Anything wired doesn't go through the orbi rbk753s. The orbi satelittes are not wired, and I am running firmware V3.2.16.22 and the app shows the 3 smart speakers, and I can ask what time it is, or what the weather is and get a answer from the device, but they won't stream music or they buffer for 20 minutes. "Alexa, play pandora" "ok, here is your station" but nothing plays. This includes audible books, amazon music, or other streaming services. The google one does the same thing. It will respond, but never actually plays. If I turn on the ISP wifi they play just fine through that but not orbi. have never logged into my orbi system other than the moblie app. These devices are very popular so I was wondering why this hasn't been fixed. The form I am filling out doesn't even list my RBR753S, so I had to choose the only one close to being what I am working with.
- vajimMaster
6172crew wrote:I have seen a few others having issues with getting the smart speakers to play, or stream but none of the issues are mine and I see no fixes.
This installation is a classic "Double NAT" (one router behind another) https://kb.netgear.com/30186/What-is-Double-NAT
I did a few searches for "Alexa and double-nat" and it appears that this is a topic of interest.
The Orbi "app" has no method of changing the Orbi from "router" to "access point" (AP) mode. It might be useful to use the Orbi web interface (http://orbilogin.net), the Advanced Tab, Advanced Setup, Router/AP Mode to change the Orbi into AP mode and see if that affects music playback.
(I can test this, but need to buy an inexpensive echo.)
- 6172crewGuide
I turned my orbi into a AP, and still have issues. No specific Network Address Translation buttons that I can see but my orbi plugs direectly into the calix fiber to prem modem. I am not using a switch, or any other devices. All of my smart home stuff is on my guest network, with a total of 14 devices.
- vajimMaster
another possible option:
use the orbi router ONLY
get rid of whatever other router you're using IF you can
- 6172crewGuide
it is a Calix gig router, a GS2020 most likely. When I logged into it last night it brings up a customer side to be able to turn on and off the wifi, and sends to you a wizard, but gives no options to play around with anything else so i might need to call uo the local provider and see if they can do more. Issue is the amazon echo works fine using the ISPs wifi, so it certainly points towards netgear orbi as the problem and there are a few members here complaining about the same thing. I do notice the echo isn't connected to the closest satellite upstairs which is odd but its able to tell me the time and weather, just wont stream or it buffers really bad, or it wont continue at all. I just moved into my home, so I am busy with other things and can't spend the time with customer support. Like some, I work in the industry and have done some basic troubleshooting before joining this forum. Only thing I have not tried is moving the smart speaker deals over to the non-guest wifi.
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry setting CTS to 2347 on the RBR. Under Advanced Tab/Advanced Settings/Wireless Settings
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
Please visiting the Orbi AX forum as well.
Good Luck.
6172crew wrote:it is a Calix gig router, a GS2020 most likely. When I logged into it last night it brings up a customer side to be able to turn on and off the wifi, and sends to you a wizard, but gives no options to play around with anything else so i might need to call uo the local provider and see if they can do more. Issue is the amazon echo works fine using the ISPs wifi, so it certainly points towards netgear orbi as the problem and there are a few members here complaining about the same thing. I do notice the echo isn't connected to the closest satellite upstairs which is odd but its able to tell me the time and weather, just wont stream or it buffers really bad, or it wont continue at all. I just moved into my home, so I am busy with other things and can't spend the time with customer support. Like some, I work in the industry and have done some basic troubleshooting before joining this forum. Only thing I have not tried is moving the smart speaker deals over to the non-guest wifi.
Also is Armor enabled on the RBR?
