- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK353 (350 with 2 satellites) VPN Error on Android mobile
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
I just switched from a nighthawk R6800 to an Orbi RBK353 mesh (RBK350 router and 2 satellites). I am really pleased with the Orbi generally, except for the VPN service.
The router F/w is V4.4.1.29_3.10.80, my Android is running version 9, and the OpenVPN client is the latest on Google Play.
I had a VPN on my R6800 which worked for 5+ years without issues, was really easy to setup and never failed me. Setting up the same service on my Orbi with new client configs for my windows and android devices has been less than inspiring - I have managed to get the Windows service working, but only after many hours of trying various web posted solutions. The one that worked for Windows was to add a line at the end of the config "Remote-cert-tls server".
However, adding that to the Android config fail achieves nothing. I get the exact same error and am now going round in circles. The full error message is:
Transport Error:OpenSSLCOntext::read_cleartext:BIO_read failed,cap=2576 status=-1:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed.
My config file is standard as produced by the router for Android - a smart_phone.ovpn which is a unified config with the certs and keys included.
I am using a DDNS (which is updated and working).
Anybody got any ideas? I would really appreciate any help here.
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @CrimpOn,
Thanks for the response. Your config is exactly the same as mine where it matters (obviously different server addresses etc - I use a NoIP DDNS pointing back to my router).
I have found a solution this afternoon though. Where the issue is, I still can't say especially as some users with OpenVPNConnect are fine, and others aren't.
The solution was to install another VPN client software, called "OpenVPN for Android" written by Arne Schwabe, and available on Google Play. While this is not my preferred option, as I would rather use the official app, it has solved the problem. It appears therefore that there is a bug in OpenVPN Connect. Odd, as other users are having no issues, and I didn't on my R6800. It only started once I had switched to the Orbi. I suspect that the "bug" is a mismatch between the Orbi server settings and OpenVPN Connect.
Interestingly, in order to eliminate a very similar issues on Windows, I had to add a line to the end of my config file:
Whatever the issues are, the solution for Android is to install and use OpenVPN for Android, and not the official OpenVPN app.
Cheers
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK353 (350 with 2 satellites) VPN Error on Android mobile
Hi all,
I just switched from a nighthawk R6800 to an Orbi RBK353 mesh (router and 2 satellites). I am really pleased with the Orbi generally, except for the VPN service.
I had a VPN on my R6800 which worked for 5+ years without issues. Setting up the same service on my Orbi with new client configs for my windows and android devices has been less than inspiring, I have managed to get the Windows service working, but only after many hours of trying various web posted solutions. The one that worked for Widows was to add a line at the end of the config "Remote-cert-tls server".
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bummer. This is using a config file produced by the new Orbi RBR350 router?
The Android configuration that I am using for an older Orbi RBR50 is this:
client
dev tun
proto udp
remote xxxxxxxx.mynetgear.com 12973
resolv-retry infinite
nobind
persist-key
persist-tun
<ca>
-----BEGIN CERTIFICATE-----
OpenVPN Connect 3.3.1 , updated Feb 22, 2023 on Android 10.
The OpenVPN log file:
08:54:56.172 -- ----- OpenVPN Start -----
08:54:56.173 -- EVENT: CORE_THREAD_ACTIVE
08:54:56.175 -- OpenVPN core 3.git::d3f8b18b:Release android arm64 64-bit PT_PROXY
08:54:56.175 -- Frame=512/2048/512 mssfix-ctrl=1250
08:54:56.181 -- UNUSED OPTIONS
4 [resolv-retry] [infinite]
5 [nobind]
6 [persist-key]
7 [persist-tun]
13 [verb] [5]
08:54:56.181 -- EVENT: RESOLVE
08:54:56.392 -- Contacting 172.249.112.236:12973 via UDP
08:54:56.392 -- EVENT: WAIT
08:54:56.396 -- Connecting to [xxxxxxxxxx.mynetgear.com]:12973 (xxx.xxx.xxx.xxx) via UDPv4
08:54:56.585 -- EVENT: CONNECTING
08:54:56.588 -- Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-client
08:54:56.588 -- Creds: UsernameEmpty/PasswordEmpty
08:54:56.589 -- Peer Info:
IV_VER=3.git::d3f8b18b:Release
IV_PLAT=android
IV_NCP=2
IV_TCPNL=1
IV_PROTO=30
IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305:AES-128-CBC
IV_LZO_STUB=1
IV_COMP_STUB=1
IV_COMP_STUBv2=1
IV_AUTO_SESS=1
IV_GUI_VER=net.openvpn.connect.android_3.3.1-9079
IV_SSO=webauth,openurl
08:54:56.685 -- VERIFY OK: depth=1, /C=TW/ST=TW/L=Taipei/O=netgear/OU=netgear/CN=netgear CA/name=EasyRSA/emailAddress=mail@netgear, signature: RSA-SHA256
08:54:56.686 -- VERIFY OK: depth=0, /C=TW/ST=TW/L=Taipei/O=netgear/OU=netgear/CN=server/name=EasyRSA/emailAddress=mail@netgear, signature: RSA-SHA256
08:54:56.840 -- SSL Handshake: peer certificate: CN=server, 1024 bit RSA, cipher: ECDHE-RSA-AES256-GCM-SHA384 TLSv1.2 Kx=ECDH Au=RSA Enc=AESGCM(256) Mac=AEAD
08:54:56.840 -- Session is ACTIVE
08:54:56.841 -- EVENT: GET_CONFIG
08:54:56.843 -- Sending PUSH_REQUEST to server...
08:54:56.997 -- OPTIONS:
0 [dhcp-option] [DNS] [192.168.1.1]
1 [route-gateway] [192.168.2.1]
2 [topology] [subnet]
3 [ping] [10]
4 [ping-restart] [120]
5 [redirect-gateway] [def1]
6 [ifconfig] [192.168.2.2] [255.255.255.0]
7 [peer-id] [0]
8 [cipher] [AES-256-GCM]
08:54:56.998 -- PROTOCOL OPTIONS:
cipher: AES-256-GCM
digest: NONE
key-derivation: OpenVPN PRF
compress: LZO_STUB
peer ID: 0
08:54:56.999 -- EVENT: ASSIGN_IP
08:54:57.021 -- Connected via tun
08:54:57.022 -- LZO-ASYM init swap=0 asym=1
08:54:57.022 -- Comp-stub init swap=0
08:54:57.023 -- EVENT: CONNECTED info='xxxxxxxx.mynetgear.com:12973 (xxx.xxx.xxx.xxx) via /UDPv4 on tun/192.168.2.2/ gw=[192.168.2.1/]'
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @CrimpOn,
Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
My DDNS is also through No-IP.com
Very puzzling. Where did my log file differ from yours?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I dont know why, but any reply I put up here is disappearing. I have tried 4 times to respond with my log file but as soon as I hit post, the message flies off into the aether.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK so that last one stayed up. It must be I'm doing something wrong with the log file. AS it is so small, I was pasting it inline directly to the post from a plain text file (so no markup). I can only assume the system has an issue with that for some reason.
I can't see how to upload the file, as the attachment box below won't accept anything other than PDF or images.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have attached the log as a PDF
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for persevering to provide the OpenVPN log file. Our log files differ at this point:
Mine:
Yours:
The difference appears to be that mine has CN=netgear CA/name=EasyRSA.
Yours has CN=netgear/name=changeme.
This information is found in the ovpn file after the first certificate. i.e.:
client
dev tun
proto udp
remote bednarhouse.mynetgear.com 12973
nobind
persist-key
persist-tun
<ca>
(certificate)
-----END CERTIFICATE-----
</ca>
<cert>
Certificate:
Data:
Version: 3 (0x2)
Serial Number: 2 (0x2)
Signature Algorithm: sha256WithRSAEncryption
Issuer: C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear CA/name=EasyRSA/emailAddress=mail@netgear
Validity
Not Before: Jul 13 19:33:02 2018 GMT
Not After : Jul 8 19:33:02 2038 GMT
Could you look at your ovpn file and see what is at that location?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Mine has:
Issuer: C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear/name=changeme/emailAddress=mail@netgear.com
I'll change that line to read the same as yours:
Issuer: C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear/name=EasyRSA/emailAddress=mail@netgear.com
I'll let you know shortly how that goes
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, so I changed that line and 2 others where the CN had changeme as the name. I did them all one at a time until all were reading EasyRSA.
Unfortunately, the changes did not work. The log file still shows the same error, and shows the name=changme in the error message.
I have attached the config as a PDF (without the certs/keys contents)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think you missed the CN=netgear CA
CN=netgear(space)CA
- Mark as New
- Bookmark
- Subscribe
- Permalink
you are correct that these appear in both the company and client certificates.
Seems very strange that your router would produce a smartphone.ovpn file that is different from mine.
Can you try downloading a new file to double check?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I cant see that. All the lines with CN=netgear/name=EasyRSA are the same
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tried a new file a few times for belt and braces. I have to now assume that the Netgear server config is suspect on the Orbi, and is producing somewhat corrupted configs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Even more interesting is that the OpenVPN for Android app is completely agnostic about the name tag. I have imported the new config (with the name= EasyRSA) and it still works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Two of the lines in mine have CN=netgear CA and one has CN=client
- Mark as New
- Bookmark
- Subscribe
- Permalink
I missed that. I have made the change and still get the error, stating that CN=netgear/name=changeme !!
I can't see where that is coming from, unless it is embedded in the cert itself...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Then other OpenVPN app has an edit function that decodes the certs, and it definitely shows name=changeme, on both the CA and the Client certs.
I think that is the problem. The implementation of the server scripts is incorrect on the Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
@CrimpOn Thanks for all your help and efforts to resolve this issue. I think I am going to stick with using the OpenVPN for Android app, as it works no matter what the CN name is.
I have marked my earlier post as the solution, so anyone else with the same issues can hopefully go down the same road, and at least have a working VPN
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
