Orbi WiFi 7 RBE973
Reply
Orbi RBKE963 6E
Tajee
Orbi RBKE963 6E
So on the 6E band can I assign devices that are not 6E capable like an iPhone 13 and PS5 to use that band or will they be unable to use it at all because they are not 6E devices.
Message 1 of 3
xyz123456789zg
Re: Orbi RBKE963 6E
iPhone 13/13 Pro/13 Pro Max and PS5 are not support WiFi 6E. Couldn't running on 6GHz.
Message 2 of 3
Guru
Re: Orbi RBKE963 6E
You can't.
6ghz is a hardware difference. Its like to connect a 2.4ghz only device to a 5ghz network. It won't work.
The only devices that can connect to 6ghz are those that have the built in capability
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 479 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
