- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR750 satelite update without ethernet
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an Orbi Mesh system RBR750 with two satellites. In the orbi app the are red in the device manager. There RBR750's firmware is current but the two satellites have dashes where the firmware version should be. (I assume RBS- means satellite).
How do you update the satellites without ethernet?
I had this similar issue over a year ago with no resolution.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
There we go. Yay.
I'd disable the Auto Update feature to be sure the RBR doesn't get updated from NG. Under Advanced Tab/Advanced Settings/Wireless Settings
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR750 satelite update without ethernet
Are they appearing in the RBRs web page as connected or disconnected?
IF they can be ethernet connected, connected them that way and use the IP address seen on the RBRs web page for each RBS and log into the RBS web page and update FW there manually:
Remember, the RBS need to be updated first before the RBR, then RBR lastly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
orbi rbr750 updating firmware
RBR=router
RBS=satellite?
The router firmware is current.
I think I need to update the satelites but do know how. I have the app but it doesn't follow the instructions in the manual: there is NO ADVANCED button or section.
How do I do this? I have an Imac, MBP and a windows box downstairs.
satellites off and on
- Mark as New
- Bookmark
- Subscribe
- Permalink
192.168.1.1
I arrived at a login but I could not login.
admin
password did not work
- Mark as New
- Bookmark
- Subscribe
- Permalink
The IP address would be different for the RBS if ethernet connected.
If there connected via ethernet and using there assigned IP address, log in may appear and admin and password should work if they don't sync. If they sync and have good signal, then use the same log in as you use on the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OKAY...I changed the password to access this thing and got in.
The RBR firmware is current
I cannot tell if the satellites are current.
I am in the attached devices section and see this screen. The two satellites bounce between connected and disconnected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah, there is the reason, you have RBS350s. These are NOT compatible with v7 of FW.
You need to downgrade the RBR back to v4 version of FW:
Please disable the auto update feature as well on the RBR after downgrading the RBR back to v4 so it won't auto update back to v7.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I downloaded the v4 software. rbr and rbs.
#1 says to select the box next to the satellite name= there is no box.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Select Disconnect for the one RBS that doesn't connect. Turn OFF the one RBS that is connected.
Factory reset the other RBS that doesn't seem connected by pressing the reset button in back for 15 seconds then release. Once the front LED begins to plusate WHITE, use the RBRs web page to Add Satellite. Do this with this one RBS placed in same room as RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
But when is RBS350-v4 software used to update the satellites. These files are sitting in my download folder but like I said in the previous message there is no box to select to update or upload the v4 into the RBS..... thank you for your patience.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can only presume both RBS were updated already to v4.
Factory reset the one RBS thats not connecting and don't do anything for about 5 minutes. With a ethernet connected PC connected to the back of this one RBS, using a web browser, you should be able to log into it's self service web page at 192.168.10.250. If you can get in using admin and password, and check to see FW version here. If it hasn't been updated, then you can updated here.
Or ethernet connect the RBS to the back of the RBR and use the given IP address for each RBS to log into the RBS web pages and update the RBS directly to there web page using the RBS files you have on your PC.
Then needs to be resynced as mentioned in previous post. Hope fully it will connect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nothing has been updated. The updates are sitting my download folder.
does it matter that I am on a mac?
I am able to log in but nothing gives me the ability to update each satellite.
at this point I have reset each sat. And unplugged one . Plugged the other next to the rbr750 and connected with an ethernet cord. Waiting a few minutes fir magic to happen.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After downloading firmware and unpacking the *.chk file from the *.zip file:
- Connect to the web interface
- Navigate to the Advanced Tab (and wait until it loads fully)
- Open the Administration menu
- Open the Firmware Update menu
- Click on the Advanced Tab
- "above the line" is a section to manually update the router
- "below the line" there should be a row for each satellite.
Click on one of the satellites and proceed to follow the directions to browse to the location of the *.chk file for satellites and upload it.
The issue is that sometimes when satellites are on different firmware than the router, they do not appear in the manual update tab.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Select the check box next to your satellite's model name. THIS DOESN'T APPEAR.
I AM ON MY WINDOWS BOX DOWNSTAIRS AND THIS DOESN'T APPEAR HERE EITHER.
This is all I see. The satellites do appear as an option
- Mark as New
- Bookmark
- Subscribe
- Permalink
...Satellites do NOT appear as an option.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This doesn’t work.
”If you can get in using admin and password, and check to see FW version here. If it hasn't been updated, then you can updated here.” I CAN GET IN, but FW VERSIONS NOT VISIBLE AND THERE IS NO WAY TO AFFECT THE SATELLITE FW. I DON’T SEE A WAY TO “update here”.
“Or ethernet connect the RBS to the back of the RBR and use the given IP address for each RBS to log into the RBS web pages and update the RBS directly to there web page using the RBS files you have on your PC“ ALL THIS DID WAS SAY IT WAS WIRED TO THE RBR.
Using the IP ADDRESSES on a MAC or a PC THERE STILL NO WAY TO SELECT A GIVEN SATELLITE FOR FIRMWARE UPDATE.!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
While disconnected (wireless to the primary Orbi router) there can't be a magic connection established.
I would look on temporarily establishing an Ethernet connection to the router (in your case the other Orbi on a LAN port).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. See response #14 and #17.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well after almost 24 hours working with volunteers here, I now have ZERO satellites in my network with NOWAY to upgrade or revert to a previous FW.
I have no idea why it is necessary to do this.
i have factory reset the rbr and the rbs a number of times, connected each individually with ethernet cable. NO JOY
THE last thing i could do is simply upload the v4 into the RBR against instructions to first update the RBS then the RBR, but right now all that is working is the RBR.
This is the second expensive NETGEAR system that we have had that has met an unfortunate and aggravating end-after the 8000 nighthawk thing.
where do I go from here? If any of you can please look through each screen shot and possibly see a button or check box that I missed to update the FW on the RBR or RBS, I will be a monkey’s uncle-whatever that means.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I this case you have to load v4 FW back ON to the RBR since the RBS are probably already on V4 FW. All you need to do is to downgrade the RBR back to V4 FW. As mentioned in my 3rd post to you in this thread.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since v.21 would not be applied to the RBS350s, these are probably still on v4 FW so there is no need to dowgrade or do any FW anything with the RBS350s. Only need to downgrade the RBR back to v4 as mentioned already.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree. When an RBR750 router is connected to only RBS750 satellites, then all of the units can be updated to the latest firmware (satellites first). When any RBS350 satellites are connected to the RBR750, they will function only if the RBR750 remains on firmware v4.6.14.3
Netgear's implementation of router-satellite communication can lead to a lot of frustration for customers when they are left with no mechanism to solve problems. When the satellite does not connect at all, there is no way to do anything.
This RBK653 "Kit" with one RBR750 router and two RBS350 satellites is obviously defective when it will allow the router firmware to be updated. The firmware should refuse to do so. "Hey, dude. There are RBS350's connected. They will be disconnected (permanently) if the router is upgraded!"
There are other ways a customer could wind up with this odd router/satellite combination. A system with zero RBS350s could get updated and then the customer attempts to add an RBS350 because the Netgear web page says they are compatible. (with no footnote about the firmware requirement).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay you guys….This makes more sense…… BUT…. Since i had no idea something like this was even possible [how is this router/satellite software mismatch possible??], i have been replacing modems and xfinity replaced our own modem that i thought was bad, with a modem with built in router, which renders the ORBI INOPERABLE… So, before I can work on the RbR, I have to reinstall the old modem by calling Comcast with the mac address…i am exhausted fiddling with this LAN stuff….and the $200 modem from amazon was used so i am send that back….so….this has been a real drag. But i appreciate you guys being there….with patience…it will be a few hours before i can install a modem only device.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
