- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBS 750 dropping speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an Orbi ax 4200 triband mesh wifi 6 system, main router and two satelites. I have Windstream Kinetic gig service. I have had this Orbi for 18 months, over the last 3 months it has been dropping speeds (based on the Orbi app) or just flat out disconnecting. I have been averaging upload and download speeds between 850 mbps and 990 mbps and over the last 3 months, dropping to 80-90 mbps. Rebooting works to reset 3 out of 5 times, but will drop again in a day or less. I have done a full reset, uninstalled, reinstalled, reconfigured, spent hours on phone with Netgear and teh problem just keeps coming back. Firmware version is V4.6.14.3_2.3.12, I have about 28 connected devices, I have found and labeled all of them based on what they are (Thermostates, computers, ect..), 2 or 3 I havent figured out yet. We work from home and can not really afford to have our service dropping out all the time, we have back mifi for when it does. Winstream has been out here and tested every thing up to the router, even connecting their own, and everthoing works fine, so the issue is the orbi. Any help is appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBS 750 dropping speeds
Instead of using Orbi app, what speeds do you see with a ethernet connected PC and wireless device using Ooklas installable speed test app?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...
Armor, Smart Parental Controls or Circle, Traffic Meter.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
