Orbi WiFi 7 RBE973
Reply
Outdoor Satellite
wifiblues
Luminary
Re: Outdoor Satellite
thanks - just curious what is the normal percentage level for the power output on the RBR?
Message 26 of 35
Guru
100% is the norm but some adjusting maybe needed.
Message 27 of 35
wifiblues
Luminary
hi there
take a look at this.  This screen shot is from the Orbi App.  it shows the RBS750 which is located outdoors in a weather proof box dotted to RBS750 which is indoors.  the Orbi app shows that the connection is solid and green - yet when i log into the router, it shows the backhaul is poor.  Why?
Message 28 of 35
Guru
I presume the Orbi app may not be correctly showing same as what the RBR shows. I've really never held the app in confidence in this area. I see same on my Orbi system with the basement RBS showing poor when wireless to the RBR on 2nd level while orbi app shows green. I presume that Orbi app maybe just not include the poort status, and onlys shows it being Online or Off line or disconnected.
If the RBS is working, I would not worry too much about the Orbi app.
Message 29 of 35
wifiblues
Luminary
the RBS seems to be functioning fine -
The app shows the green dot, the orbilogin shows the poor backhaul -
the app shows a dotted connecton to the RBS that's indoors and closest to the RBS outdoors in the weather box.  is the dotted connection between the two satellites a result of daisy chain being on?
Message 30 of 35
Guru
Yes, that DC in action. Automatic too.
Message 31 of 35
wifiblues
Luminary
then maybe likley reason why the orbilogin to the router shows poor backhaul but the app displays a green connection to the closest satellite.
Message 32 of 35
Guru
Could be a reason...
Message 33 of 35
wifiblues
Luminary
i logged into the RBS IP address and could not figure out if the RBS (outside) was listed as a  connected device.
Message 34 of 35
Guru
Not sure if it will appear on the host RBS connected device list...I presume it may.
Message 35 of 35
Top Contributors
Discussion stats
  • 34 replies
  • 5987 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
