Orbi WiFi 7 RBE973
Reply
RBK852 2.4 GHZ dropout
stackmann
Follower
I HAVE A SMART HOME WITH 48 DEVICES AT 2.4 GHZ. I PURCHASED A RBK852 (WITH ONE SATELLITE) AND AM STILL HAVING ISSUES WITH DROP OUTS. IF I ADD ANOTHER SATELLITE, WILL IT CORRECT THE ISSUE?
Message 1 of 3
Guru
Re: RBK852 2.4 GHZ dropout
No need to yell.
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
Message 2 of 3
Guru
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 515 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
