- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR 960E Rebooting every 2 Minutes
- Mark as New
- Bookmark
- Subscribe
- Permalink
I updated to the latest firmware of My 3 year old RBR 960E Router two days ago and today my router started rebooting every 2 minutes.
Worked with Netgear tech support - first hard reset the router but no luck.
I then rolled back to one previous version firmware but problem persists.
Netgear told me to observe 24 hours and then discuss - the router is out of warranty...
Will appreciate any help on how to solve this issue..
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for responding to my cry for help...
Turns out that one of my Araknis Switch (snap av) with OVRC (cluod management) was the culprit in this setup...
I attached a OVRC Wattbox cloud power controller to this switch and the switch got corrupted and all hell broke loose.
After the weekend of troubleshooting I took the switch of my network and all is stable.
I did roll back the firmware to October Version and let the firmware there..
So problem solved - it was not the ORBI but the Switch,
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR 960E Rebooting every 2 Minutes
The RBRE960 isn't 3 years old. It was released in december 2022. So its 1 year and 1 month old. Unless you literally purchased it on the release date, it should be in warranty.
Did you check your power supply for it? See if one of the satellites has a matching power supply you could see if it worked.
After you're factory reset, are you leaving it with just the defaults running? (also, don't install it from a backup)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it figured out!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
