Orbi WiFi 7 RBE973
Reply
can not see whats connected to rbs350 satellite
billhyd
Follower
i just bought a RBR750 and 2 of RBS350 came as a set, its all hooked up and works good, but i can not see whats connected to the rbs350 unless i log into them. firmware for the rbr750 isV4.6.14.3 and the rb350 is V4.6.3.16, from what i have seem it seems like it is a firmware issue i was going to to see if there was a newer version to update it to, but all there is a older version than what i have not sure what to do ?
thank you for any help on this.
Message 1 of 2
Guru
Re: can not see whats connected to rbs350 satellite
You need to update the RBS to same version of FW:
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/New-RBK653-Firmware-Version-4-6-14-...
Be sure to remember to update the RBS first, then RBR lastly.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 284 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
