- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
RBR750 major issues after FW 4.6.3.7
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR750 major issues after FW 4.6.3.7
Disable AX mode on the RBR. Other posters mentioned this helped them in for the time being.
NG is aware of the problems on this version of FW.
@MeowWifi wrote:
I have the same issues with my RBR752, that I think I've narrowed down to the FW also. It was stable for a long time, and then it just started having issues. Reading your post makes me feel better, I was starting to think I was going crazy.
It's been stable for months, but now I have the issue where my Satellite constantly disconnects. Trying to figure out the issue, I actually factory reset the router. And when doing so it actually broke the wifi. The router believed it was sending out an SSID, but in reality there was no signal. I ended up RMAing it. I got the new one, but the satellite is still borked.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
We don't get any update information from NG. NG seems to know whats going on and working on it.
For now, NG told one user to diable AX mode on the RBR and that there maybe problems at the RBS. Disabling of AX mode on the RBR seems to have helped some users.
@Theobuck wrote:
Has there been any updates on this issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is this the settiing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can't see the inline picture. Please use the Choose File button to attach the capture file to a post.
AX mode is seen on the Basic Tab/Wireless settings. Two check boxes marked 2.4 and 5Ghz AX mode. Un check these and apply disables AX mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Give it a couple of days...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
ALL USERS of the 7 series Orbi AX system, please contact NG support by opening a support ticket and contact NG and ask them for the beta that seems to be avialable for the 7 series that seems to be directed to fixed what everyone with a 7 series has been having problems with:
https://www.netgear.com/support/#
For user out of warranty, contact @Blanca_O and @DarrenM and send them a PM and ask for the beta.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The version looks the same.
https://kb.netgear.com/000063818/RBR750-RBS750-Firmware-Version-4-6-3-7
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bug Fixes:
Fixes the DNS timeout issue
Fixes the issue where a phantom satellite appears in device list
Various other bug fixes
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’ve about had enough of Orbis. Updated to newer models to get better coverage and has been nothing but problems. Cannot keep spending time every week to run reboots and problem shooting. Even the horrible Verizon router can’t be this bad.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you using v7 of the FW, this version has been superseded by v4.6.5.14:
If your having issues, please post there or make a new post and we'll try to help you out.
Thank you.
@Mstone4211 wrote:
Same here. Nothing but issues since the update. Will work for maybe an hour after rebooting, and back to it. I have the fun opposite that my router has no color band, but this is my app. Satellites work (hardwired) and can get Wi-Fi from them - though one constantly loses connection and reconnects in a never ending blue/white lights cycle (fun to have in my bedroom).
- « Previous
- 1
- 2
- Next »
