Orbi WiFi 7 RBE973
Reply
RBR750 will not connect solid amber power Led
Dolphins
Trying to set up the ORBI Router for the first time, the router when plugged into the power supply the power led light stays in a solid amber state. I have tried swapping the power supply with the satellite unit no change. Both power supplies power up the satellite unit.
I have tried utilizing the ORBI app to set up but the router is not sending out a WiFi network.
Message 1 of 4
Guru
Re: RBR750 will not connect solid amber power Led
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
Message 2 of 4
Sounds like it is stuck at booting.
If a reset doesn't unstuck it, then it sounds like it is dead on arrival. Bet take it back to whoever supplied the thing.
Message 3 of 4
Guru
Any progress on this?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 617 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
