Orbi WiFi 7 RBE973
Reply
RBR850 Configuration Issue
vksvicky
Follower
I have RBR850 with Firmware V3.2.15.25_1.3.15, here are my issues?
1. I could never get the Android app to recognise the device and connect. I updated the name of the device (vORBI11) to something other than the default (RBR850), and still the app won't recognise the device, I have to connect via browser using an IP
Is there a way to solve this?
2. I am using Sky as my broadband provided and had put the Orbi on Router mode, is this correct?
3. When I change WAN Preference from Internet Port to WAN aggregation, I don't have Internet, is this the correct setting?
4. I have enabled Remote Management and still I cannot connect to the Orbi via Remote Management. Anyone know why?
Message 1 of 2
Guru
Re: RBR850 Configuration Issue
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Does your ISP modem support Aggregation? If not then you can't use LAG.
See #2 response above.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 610 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
