Orbi WiFi 7 RBE973
Reply
RBR850 / RBS850 WiFi WPA-3 and 6Ghz
While configuring my WiFi security on my new Orbi mesh system I realized I cannot set my security method to WPA-3-Personal due to some of my devices not supporting it and thus not connecting. I am curious though because at the bottom of the config page it says "Note: 6GHz WiFi supports only WPA3 encryption" Does my system support WiFi 6GHz? I'm confused since I thought it was a 6E capability. Can someone explain to me the meaning of that Note? I believe I read somewhere the satellite communicates with the router on it's own secure/islolated backhaul frequency, however the satellite shows connected to the router on the 5GHz frequency. It there a relationship here?
Message 1 of 3
Accepted Solutions
Guru
Re: RBR850 / RBS850 WiFi WPA-3 and 6Ghz
Orbi AX is WiFI6 only, not 6E. It supports WPA3 single mode only. There is not mixed WPA2/WPA3 modes. There were problems found with mixed mode. Also WPA3 has been compromised. So keep to WPA2 and AES for now.
Message 3 of 3
All Replies
Guru
I'm betting its an app error in preparation for 6E. The only 6E router netgear currently makes is the RAXE500 and it hasn't even been released yet.
Message 2 of 3
Guru
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2833 views
  • 5 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
