Orbi WiFi 7 RBE973
Reply
RBS850 wired backhaul poor connectivity
RVORBI
Tutor
Hi, I have an ORBI RBR850(router) and two ORBI RBS850(satellites). However, I am having huge problems with internet stability. I will try to describe it in as much detail as possible.
I have a fiber optic internet connection from a Dutch ISP. I am using a Genexis modem to which I have connected my RBR850. I have set the RBR850 as an access point (AP) because it is not possible to set the GENEXIS modem as a bridge.
The first satellite is about 25 meters / 80 feet away. I wired this to the router with a UTP cat 6u cable.
The second satellite is again 6-7 meters / 20-25 feet away from the other satellite. This is wirelessly connected to satellite number one.
Now I am experiencing the following problems:
  • Satellite 1 regularly switches the backhaul status from good to poor to no connection at all (magenta pulse). And after a couple of minutes it gets back online.
  • Satellite 2 is dependent on satellite 1 and often does not provide a connection. However, if satellite 1 works again, satellite 2 will not provide internet.
The RBR850 (router) always gives a stable signal and when I am connected to it there is no problem at all. High speeds and low ping.
But the satellites are really disastrous, sometimes (if I'm lucky) everything works perfectly and the internet connection is just stable for hours. But usually the connection is lost several times within 30 minutes or no internet signal.
I've had the RBR850 set up as a Router in the past. I changed this setting of the ORBI 850 to Access point because I thought it might conflict because there were two routers connected to each other. (Genexis > Orbi). Unfortunately I have exactly the same problems.
I've switched the satellites positions, but still the same problem.
Maybe Im doing anything wrong in the setup, but I dont know what to do anymore. My wife and kids are driving me crazy because they cant have a stable internet connection (and believe me, that's worse than the internet connection itself 😂)  I also made a drawing of the setup for clarification.
Message 1 of 8
Accepted Solutions
ekhalil
Master
Re: RBS850 wired backhaul poor connectivity
- what other wired devices do you have connected to the router or the satellites?
- Please test to make router forget any wireless pairing with satellite 1. Disconnect the cable and in the web GUI (orbilogin.com) under “attached devices “ when you see the satellite marked as offline and you see a “Disconnect” button beside, click the Disconnect button to forget the pairing. Then do a factory reset for the satellite. Now never press the sync button without the cable being connected between router and satellite 1. Now connect the cable and press the sync buttons on both the router and the satellite. This way you have the router only paired on the wired backhaul. I had similar issues some time ago and that was the only work around to fix it.
Please also make sure that you have the latest firmware 4.6.9.11
Message 4 of 8
All Replies
Guru
When you switched the satellites, you had the exact same issue of the hardwired satellite having issues?
Any chance you have another ethernet cable sitting around you could test?
That seems to be the only common factory.
Is the satellite hardwired directly into the router or does it run through a switch?
Message 2 of 8
RVORBI
Tutor
Yes, same issue.
Not as long as this one I'm using now, I've used others to test as well but the problem remains.
Connected directly to the ORBI router.
Sometimes it also seems like the satellite is making a wireless connection to the router instead of wired, but the satellite is too far from the router (25meters/80feet) I think?
Message 3 of 8
ekhalil
Master
Message 4 of 8
RVORBI
Tutor
Hi  ekhalil, thank you for your response.
No other devices are wired to either the router or the satellite.
I'm going to try your solution tonight, I'll let you know if there is any improvement. Thank you in advance!
An additional question, did you set the RBR as a router or AP? Or does it not matter in this case?
Message 5 of 8
ekhalil
Master
@RVORBI wrote:
..... did you set the RBR as a router or AP? Or does it not matter in this case?
It should not make a difference for this issue. The issue here is likey caused by internal loops between wired and wireless backhaul interfaces.
Message 6 of 8
RVORBI
Tutor
@ekhalil I did exactly as you described and the internet has been stable ever since. (So ​​far, so good!) I think it has been the solution! Thank you very much for the solution and the effort!👍
Message 7 of 8
ekhalil
Master
Glad that this helped. I hope it will stay stable and you will enjoy a good wifi network!
@Blanca_O, this issue was there a long time ago and it seems it's now coming back in the latest firmware releases. The issue likely happens because of loops when the setup has both wired and wireless backhaul. Appreciate it if you can have a look into this.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 4541 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
