- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rbk852 dropping devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
The OBI can connect and even make a call via wifi but after a few minutes, it loses the wifi signal. I have two different OBI devices that have the same problem. Its the strangest thing. My OBI has a dual band wifi...
I also started having trouble with my circle device. Any devices that were monitored by the circle cannot connect properly. All other devices were fine. Turning off the circle (or disabling the protection) worked.
My gut tells me the problems are both related. Thanks in advance for any help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rbk852 dropping devices
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Test the Orbi AX with AX mode disabled.
For any Circle related problems, please post in the Circle forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
There are known problems with Circle causing disconnects on Orbi AC systems and is advised not to use Circle until NG get that fixed.
